Bott Clock
Discussion in 'Wood Movement Clocks' started by ristomailer, May 1, 2017.
  1. ristomailer
    ristomailer Registered User
    May 1, 2017
    Green Valley, Arizona
    Interesting old clock. The only thing missing is the two box weights on the yoke and part of the hand.
    The clock works if I move the flywheel by hand, but does not with the rope and weights installed. The rope tends to slide on the pulley rather than actually grip the pulley and turn it.
    All the gears and gear shafts seem appropriately free, easy to turn and not out of alignment.
    Any ideas?
  2. ballistarius
    ballistarius Registered User
    Oct 26, 2009
    702
    Architect
    Bilbao, Basque Country
    Welcome to the MB, ristomailer:cool:
    You seem to be describing a repro of a 'mediaeval' clock with vertical crown wheel and foliot escapement. Real clocks where constructed in rural areas as late as 17th-18th century and first 'modern' repros started to be made as early as late 19th.
    Some pics of your movement would help. Perhaps you need to tie a counterweight at the other side of the rope, or perhaps you should use a diffferent kind of rope... We need to see.
    Aitor
  3. ballistarius
    Oct 26, 2009
    702
    Architect
    Many thanks for the pics.
    I am not a clock repairer and there are dozens of people at this MB more qualified than I am. This said...
    What do you call the flywheel? The escapewheel or crownwheel seems to be misaligned, out of vertical. Both pallets of the vertical verge should be at the same distance from the crownwheel pins.
    If the rope slides on the pulley, given that you have a seemingly correct counterweight and rope, could be caused by a slightly jammed movement. Even if you can move it by hand, if the force you must exert is bigger than the friction of rope against pulley, the rope will slide, rather than move the cogwheels.
    A Spanish 18th century clockmaker wrote that, ideally, the friction of rope against the pulley on the great wheel should be such as to keep the counterweight in place, if you removed the main weight.
    You could increase the friction by 'refreshing' the carvings on the pulley, but I'd rather try to get the movement going more freely first.
    My two cents:cool:
    Aitor
  4. ristomailer
    May 1, 2017
    For lack of a better description the flywheel is the wheel with the ratcheted pulley wheel that distributes the energy from the cord to the other gears in the clock.
    It's misalignment is how it appeared to me as well. Without the cord the entire mechanism moves freely. However with the cord and weights in place part of the gear set appears to move into a bind from the weight.
    The clock appears easy to take apart, however it's construction makes me think any attempt at disassembly may destroy part or all the structure.
    I doubt these clocks have much monetary value and in it's current condition it has more value as an unusual conversation piece than anything else working or not. Although it would nice to have it working as intended. But, then I'd have to fix the hand and know how to set it.
  5. ballistarius
    Oct 26, 2009
    702
    Architect
    C'mon, don't give up so easily!;)
    You've got the perfect clock for 'playing' a little: Unexpensive and simple.
    All that you've got to do is to remove the verge and three wooden pins.
    The verge shouldn't be hanging from a coiled spring, you should use a piece of thread knoted to form a loop, instead. Remove the spring and then the verge bar, upwards, inclining it carefully.
    [​IMG]
    Put the clock on its back. Then, remove the pin nr 1 retaining the damaged hand. Once hand and pin are out, then remove pins 2 and 3 and the front platine with the dial. all the wheels will be free to inspect and clean pivots and bushings. if pivots and bushings are metal, you should oil them after reassembling.
    Aitor
  6. Tinker Dwight
    Tinker Dwight Registered User
    13,680
  7. ristomailer
    May 1, 2017
    Disassembly of wood pieces that have been in the desert for a long time can turn them into kindling without much effort. Did get it disassembled in one piece. Cleaned and lubed the pivots and bushings. Reassembled, adjusted the alignment of the top gear so it was square with the gears underneath and the back of the face. Seems to work easier as you might imagine after be cleaned and lubricated a little. As before with the weights in place it will run for a short time then stop. I suspect the missing weights on the ends of the yoke may have something to do with that.
  8. ballistarius
    Oct 26, 2009
    702
    Architect
    That's good!:clap:
    Have you already put a cord/thread suspension at the verge? You can find how they look like on the thread that Tinker has posted.
    As to the little weights, yes, the clock needs them for regulating velocity, but without them the foliot should be just oscilating wildly, like a 'modern' clock with the pendulum removed...:confused:
    Anyway, you can use a pair of small lead fishing weights, attach each of them to a wire loop and hang them on the foliot. Both must be hanging at the same distance from the verge axis, otherwise, the clock will stop. The closer to the centre, the faster will the clock go.
    You've almost done it!:coolsign:
    Aitor
  9. ristomailer
    May 1, 2017
    Replaced the spring with a short string as pictured. Runs for 30 seconds slowly, then stops.
  10. Tinker Dwight
    13,680
    Make sure the verge pallets are smooth and polished where the pins
    hit them. There can't be any rust there.
  11. ristomailer
    May 1, 2017
    Nice and shiny with no rust.
  12. ballistarius
    Oct 26, 2009
    702
    Architect
    Have you already put the little weights on the foliot?
    Aitor
  13. ristomailer
    May 1, 2017
    I tried some temporary weights out at the ends and no weights at all. Not tried moving them toward the center yet. Need to make a small hanger to do that. As you stated, without any weights I'd expect it to run run very fast, but instead it only runs slowly for about 15 seconds, then stops.
    Assembled all the gears seem to be aligned correctly, move back and forth slightly in the frame and the gears on each axle mesh nicely. Think I'm going to have to take it apart again and reassemble it one gear at a time and try the mechanism until I figure what causing the problem.
  14. ballistarius
    Oct 26, 2009
    702
    Architect
    Maybe the verge pallets engage too much with the escapeweheel pins and you should place verge and wheel a little more apart? Waht do you think Tinker?
    Aitor
  15. Tinker Dwight
    13,680
    I think I'd need to see a video before I could recommend any thing.
    Even then I may not be sure.
    These need beat setting just like any clock.
    You should try it without the pin wheel. The pallets should be even
    on either side.
  16. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Get rid of the spring you are using as a suspension. That will not work. It is suppose to have a thread suspension. A loop of cotton thread is all you need.
    Like this but neater:
  17. ristomailer
    May 1, 2017
    I'd say that's the problem. If I slide the wheel with the pins back slightly it begins to work. Stops when the when moves forward again. Looks like I can bend the axle mount for the wheel slightly to move the pins back a little.
    Thanks.
  18. ballistarius
    Oct 26, 2009
    702
    Architect
    Keep us informed!:cool:
    Aitor
  19. leeinv66
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Sorry, I missed the earlier post where you said you replaced the spring. There is some good information on the pallet flags in this thread: Click Here
Similar Threads - Bott Clock Forum Date
wooden clock gears Wood Movement Clocks Oct 13, 2017
Retangular Hoadley Tall CLock Dial Wood Movement Clocks Aug 11, 2017
DN & R Day, Westfield Mass. shelf clock Wood Movement Clocks Jul 30, 2017
Making a hang on the wall wood clock Wood Movement Clocks Jul 28, 2017
