Jeremy Woodoff
I have a clock with the Botsford so-called "grasshopper" escapement in a "PARIS" front case sold by Jerome Manufacturing Co, also seen with a label of Coe & Co., New York. See pictures and video. In the lever escapement there is an upward pointing pin attached to a brass disc on the balance wheel arbor. This pin interacts with the lever fork. Fixed to the bottom of the lever is a vertical pin that points down towards the brass disc. As the disc rotates, the pin doesn't quite touch the edge of the brass disc. What is the purpose of this pin? Should it be in contact with the disc?
There is an occasional problem with the clock, especially when fully wound, when the pin attached to the balance wheel ends up on the wrong side of the fork, stopping the clock. I don't know how that happens. The clock easily ran for two days on a winding for many years. When it began to stop before the end of the second day, I cleaned and oiled it. Since then it won't run for more than a day, as if it's losing power near the end of the run. The bearings for both the balance wheel and lever are both adjustable up or down with a screw, and I've tried many different adjustments. I'm wondering whether the pin described above might have any relation to the current problems.
