Very recently I came across an interesting mirror clock. Most mirror clocks are of the New Hampshire persuasion, but not always. There are very few period mirror clocks made with woodworks. There was a fantastic one in Chris Brown's collection years ago. They seem to be generally of a Boardman origination, and a couple are seatboard groaners, movement by Boardman, not Ives and Lewis, etc. This clock is not quite in the same condition as Chris's clock, but it is what I got. Clearly labeled Boardman. While it is pretty grungey, it is rare IMO, and that gives it value to me. It has something I have not previously seen, namely rectangular tin can weights with wood tops. It is a traditional groaner movement, perhaps of the second version of the movement, offered to the market a bit before the much more famous bronze-looking glass clock by Jerome. So, this clock might date as early as 1822 or up to about 1824. It is interesting that the mirror extends up above the edge of the case. Since all clues suggest all parts are original to each other it would seem the clock was made in this fashion to hide the bell and strike hammer from causal view. Later groaners have a splat to do the same. All the dirt (patina) lines and shadows all correspond properly, so there is no need to become over-concerned with additional mirror height.
The tin can weights are certainly of interest to me, never have I seen quite this approach to groaner weights. It appears as if they are original to the clock. There are only a very few of these groaner mirror clocks, maybe 3 or 4 others out and about in the last 25 or more years can be found in photos from all the usual sources. The only real repair has been the repositioning of the hinges. How can one chisel out new pockets for the hinges but not have toothpicks and glue to repair the screw holes in the original locations?
I am most pleased with this beast. to grab this one up.
