Blick Time Recorder Question
Discussion in 'Electric Horology' started by timelyrestorations, May 2, 2020.
  2. It's Coming
    Just Two More Days
  1. timelyrestorations
    timelyrestorations Registered User
    Jan 26, 2001
    846
    Just picked up a Blick Time Recorder in oak case. It has two small gauge wires protruding through the case. What current do these clocks run. Could I just wire a standard 110 plug to the existing wires and see if it runs, or am I going to damage something?
  2. RODALCO
    RODALCO Registered User
    Mar 27, 2006
    275
    Electrician
    New Zealand
    I can't see the type of motor attached near the coil.
    At this stage don't wire it up to the 110 Volts mains as most likely you will burn out that coil within seconds.
    Can you take a picture of the actual motor please.
    If you have an Ohm meter, do a continuity check of the coil.
  3. timelyrestorations
    Jan 26, 2001
    846
    Thanks Rodalco;
    Bear with me, as my electrical knowledge is limited at best. The wiring goes directly to the coils. There does not appear to be a motor. I'm assuming, due to this, that this was powered by a master clock? If so, how complicated would it be to have it self powered?
  4. RODALCO
    Mar 27, 2006
    275
    Electrician
    New Zealand
    It looks like coils for an impulse to advance or charge a spring to drive the mechanism.
    Most likely 12 or 24 Volts DC.
    It looks that your clock has a pendulum on one of the photo's.
  5. timelyrestorations
    Jan 26, 2001
    846
    No pendulum, and no spring. It has two "fingers" that are spring loaded and advance the wheel one tooth each time the coils impulse. Here are a few more photos.
    Kevin W. likes this.
