Black Forest Shield Sharpie Numerals
Discussion in 'Reverse Glass and Dial Painting' started by gleber, Jun 20, 2016.
  1. gleber
    gleber Registered User
    Jun 15, 2015
    725
    I just picked this up today. Does anyone have any suggestions on how to remove the Sharpie numbers. They are quite poorly done as you can see. I'm hoping there is some solvent that would only remove the ink.
    More photos of the whole clock in the Latest Acquisition section.
    Thanks,
    Tom
  2. novicetimekeeper
    Jul 26, 2015
    4,736
    I use ethanol to remove permanent marker at work but you need to try it on an edge to make sure it doesn't soften the paint. I don't think it will remove it all though as it will probably be deep in the paint but it would remove the surface.
    Ethanol isn't much of a solvent so it is worth a try.
  3. gleber
    Jun 15, 2015
    725
    Thanks Novice,
    I don't have any Ethanol, but I experimented with some Isopropyl, and it doesn't take too much elbow grease to clean up. I was surprised - it came off easier than expected and exposed white numbers underneath. I did notice faded white quarter hour numbers, but didn't expect the hours to be white.
    Tom
  4. leeinv66
    leeinv66 Super Moderator
    Mar 31, 2005
    7,959
    12
    The white numerals are the shadow left once all the paint from the original numerals has been removed. Is that what you intended to do?
  5. gleber
    Jun 15, 2015
    725
    Possibly a good point, but I only see signs of Sharpie, no paint (so I don't think I removed any). The black Sharpie was poorly done and doesn't even come close to matching the white outline. Would the quarter hour numbers have been black? I can see a faint outline of white, but no sign of black on any of them. You can see the 30 in the photo above. That is what i was basing my comments on. It doesn't look like it ever had black? Or, if it did, it seems like it was completely gone before the Sharpie was applied by a former owner.
    Thanks,
    Tom
  6. novicetimekeeper
    Jul 26, 2015
    4,736
    Methylated spirits is mainly ethanol so that works just as well, just smells bad.
    Glad it worked, now you need to repaint the numbers. It's a skilled job, I'd need to get somebody else to do it!
  7. leeinv66
    Mar 31, 2005
    7,959
    12
    Tom, I have seen many, many of these shield clocks and I have never seen one with white numerals. What you have left is where they stencilled on the outline of the numerals. They then filled those in with black paint that was applied with a brush.
  8. gleber
    Jun 15, 2015
    725
    I am working on my skills and am sort of looking forward to this challenge.
    Tom
  9. gleber
    Jun 15, 2015
    725
    Yes, that makes sense and I agree, but I wonder where the original black paint went? I can't find any signs of it. I'm not sure if you can see it, but the white outline is visible along the sides of the numeral II in this close up. And the quarter hours numbers that were not Sharpied don't have any signs of black. I'm not doubting you, but it's as if they cleaned the original paint off (and did a good job) before applying the Sharpie (poorly)?
    Tom
  10. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    The white is the original color of the shield. It had been
    protected by the original numbers from light for many years.
    The original were most likely some form of India ink that
    the binder had failed over the years and washed off.
    The numerals may even be raised a little as the original
    shield white oxidized and wore off.
  11. MartinM
    MartinM Registered User
    Jun 24, 2011
    2,302
    Yes. It seems pretty obvious that some easily removable (likely, water-based) paint or ink was originally used for the numbers and applied over the more durable white paint. It makes sense, really; As, if you were applying the numbers, originally, and there was some kind of a slip, you'd benefit from the ability to wipe off the error and start, again. I'd bet that they just didn't apply any seizing to the finished product to set the numbers.
    I doubt is was a simple failure of the original paint/ink, as there would be more examples out there of clocks with white numbers due simply to time.
  12. gleber
    Jun 15, 2015
    725
    Thanks for the good info guys. It does look like the white is raised a bit over the background. So with all of your help, the conclusion seems to be the dial had black numbers that wore of completely, and then someone came along with a Sharpie and only did the hours.
    Does anyone know of any dial painting tutorials?
    Tom
  13. dAz57
    dAz57 Registered User
    Dec 7, 2011
    1,865
    #13 dAz57, Jun 22, 2016
    When I clean a white dial prior to redoing the numerals, that's what you see, an outline of the original numerals, generally the ink yellows the white paint which is good because I can work out what the original lettering and numerals look like.
    Roman numerals are the easiest to do, use drafting ink pens, rulers and compasses, draw the outlines first then fill them in.
    This particular dial was real bad, the paint was flaking off the metal(tin), took 2 minutes to scrape the old paint off, after etch primer and acrylic lacquer I used the stencil I made, the result is as close to the original I could get.
    20140801_145838.jpg 20140801_153207.jpg 20140803_124245.jpg 20140803_124319.jpg 20140803_154819.jpg 20140805_124121.jpg IMG_20140809_102533.jpg
  14. PatH
    PatH Registered User
    Dec 5, 2014
    171
    The August 1988 Bulletin, page 298, has an article by James B. West called "Let's Paint a Dial" in which he describes the steps for painting a dial. I think the article should give you an idea of what's involved and how to get started. There is also an online video called "The Art of the Painted Dial" by M.F. Tennant (591D). You'll have to be logged on to the NAWCC website to view this video that provides a great overview of restoring a white painted dial.
    Just a couple of sources that might help provide some background.
  15. gleber
    Jun 15, 2015
    725
    I cleaned off the numbers and reapplied them. I didn't want to paint them completely opaque since the artwork is faded and I am probably not going go through the expense of having that professionally redone. I used a black ball point pen and outlined them and then added a hatch pattern. I like the overall look, but might go back and darken it just a bit more. I found the ball point pen didn't cover completely opaque and it preserves the well worn look. What do you think?
    Tom
  16. novicetimekeeper
    Jul 26, 2015
    4,736
    It is a huge improvement in draughtsmanship, but I agree could be a bit darker.
  17. gleber
    Jun 15, 2015
    725
    Thanks Novice. Now I'm another step closer to actually doing that.
    Tom
  18. Jeremy Woodoff
    Jeremy Woodoff Registered User
    Jun 30, 2002
    3,913
    I would have used an ink or paint that is easily reversible, that would come off with a solvent that won't affect the rest of the dial. Ball point ink may be difficult to remove; it also may bleed over time into the surrounding paint.
  19. gleber
    Jun 15, 2015
    725
    Thanks for the comment Jeremy. I knew I didn't want opaque black since I probably won't attempt the artwork and can't afford a professional and don't think the clock is worth it. The previous sharpie version didn't look right even if it was done neater. It was either redo completely or work with what I got and try to preserve the look. I chose the latter. I was able to clean up my mistakes very well with a simple pencil eraser, but I think the ink is beginning to set. I can still erase some of it, but not as cleanly. The shade is just about right from across the room and it looks equally worn with the rest of the dial. I didn't think about the possibility of bleeding, but the painted surface does not seem very porous, so I hope I don't end up saying, I should have listened to Jeremy." And, hopefully I won't ever have to remove it.
    I do appreciate hearing your opinion.
    Tom
Similar Threads - Black Forest Shield Forum Date
What was used to black out the glasses on early to mid 1800's Banjo's, etc. Reverse Glass and Dial Painting Mar 30, 2011
Repainting a black background on glass Reverse Glass and Dial Painting Jul 4, 2010
Black Dial, Gold numbers Reverse Glass and Dial Painting Aug 30, 2009
