• Upcoming updates
Black Forest Cuckoo Clock
HUDD
Apr 11, 2004
536
24
73
St. Albans, UK
Here are a few pictures of my wife's grandmother's cuckoo clock. I've been promising to fix it for nearly 3 years now so I finally bit the bullet. Apart from a badly replaced pivot to the going train second wheel ( looks like a machined down screw thread but it is polished and hasn't damaged the pivot hole ), some slightly bent "spokes" to the going train 3rd wheel and a loose cap to the going train spring barrel it looks to be in good order.
The barrel cap has a tapered edge and the corresponding barrel is machined with a groove to accept the cap. I haven't come across this particular design before and it looks as though the tapered edge of the cap will be damaged if I try forcing the cap into position. Is there a different way to fit the barrel cap without fear of damage ? I would also be interested if some kind person could advise the age of this clock ?
R&A
Oct 21, 2008
4,218
109
Some of these caps are hard to relocate back in place. For future reference, try marking the caps and the barrel they come off of. Barrel will distort after time and it's important that they go back on the same way they came off. I use a small wood mallet. Some times I have to put them in a vice with soft jaws. Clamp down half and then smack the other half with the mallet to pop it into place. Vice jaws will damage the surface if you don't use soft jaws.
harold bain
40,853
192
74
Is that tiny spring in your last picture out of one of those barrels? I use small clamps to put the cap back on, working one clamp around until the cap is snug all the way around, while holding a spot close to the hole tight with a second clamp. At one point you feel a snap as the cap is fitted in place.
HUDD
Apr 11, 2004
536
24
73
St. Albans, UK
Thanks Tinker for the dating. This clock is out of my normal sphere of activity, and I confess it has posed numerous problems not least the spring barrel caps. I have however got the new springs in their respective barrels and fitted the caps as per R&A's advice. Next time ( if there is a next time ! ) I shall give Harold's clamping method a go. Anyway, after a narrow squeek with a broken pinion ( one tooth broken off due I think to fatigue ) I managed to replace using a 6mm dia x 10 leaf steel pinion from and old movement, the movement complete with cuckoo is now reassembled and running well. I shall get on with the case repairs now whilst I time the movement.
Oh, that old spring ? It came from a Hamilton 3992B that I managed to buy recently and overhauled a week ago. Sorry for the confusion.
Mike
HUDD
Apr 11, 2004
536
24
73
St. Albans, UK
So much for thinking I had got this clock sorted !!! Not long before it began stopping. Sometimes after a couple of hours and sometimes after half a day. Seems the pallet pivot holes had worn more than I thought and the pallet engagement with the escape wheel was too deep. Got that sorted then one of the bellows hinges split. Not sure if that was old age or my ineptitude. Anyway, repaired that. Then the clock would strike out of sequence after running just fine for a couple of days, but seems to have righted itself now ( fingers crossed ) ? Why do I get this feeling my mother in law is trying to tell me something ?
Anyway, Here are a couple of pictures with a couple of questions. Firstly can anyone attribute a maker to this clock ? and secondly, is this the correct winding key ? I ask because it looks too industrial, and a smaller replacement key I have needs too much wrist power to wind up these large mainsprings ?
Mike
13,666
94
It does not look original. I'd stay with the wider key.
The original was most likely cast iron. It was most
likely lost or broken over the years.
HUDD
Apr 11, 2004
536
24
73
St. Albans, UK
Thanks Tinker I was worried that with the leverage this key offered I could possibly do some damage. I shall look out for a more suitable period key Mike
179,016
1,570,212
54,047
aztrukin
909
3,088
Swiss Fake by Kent
