Black Forest Clock Co. Toronto
Discussion in 'Clock Repair' started by Bill Manders, Feb 24, 2017.
  1. Bill Manders
    Bill Manders Registered User
    Feb 21, 2008
    786
    33
    Prince George
    This is one of the clocks I have had for some time, and over the period I have become quite proficient, ( I think ) at setting the beat on a clock by adjusting the crutch. but on this one I seem to be having a bit more trouble. It will go for about a minute, maybe 2, and then stop on me. Everything looks good within the movement, no excessive play etc., anywhere.
    Is there something else I should be looking at, that is normally as easy as that adjustment, or is it likely I have just lost my touch ?
    This is really a nice clock and is a Westminster chime, would love to get it going. I say all this keeping in mind my watch/clock repair skills on a level of ten is about -5. I am also missing the domed glass front, if someone knows where they can be found please let me know.
    Thanks for any help or suggestions.
    Bill
  2. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    152
    deceased
    A nice Toronto made clock from the 1930's. Seems you are missing the pendulum, which would make beat setting difficult. The bezels often go missing on these as there is not a lot holding them in place. It would be difficult to find a replacement.
  3. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,561
    176
    Carson City, Nevada
    I have had good luck getting domed face glass from jrclocker on eBay below is one his items which is 5 inch diameter. I have no idea what size you need, but jrclocker usually has just about any size and accepts messages for a request for a particular diameter.
    http://www.ebay.com/ item number 192060006389
    There are also other vendors on eBay you will find by searching 'clock face glass'. The measurement you need to make is quite precise and tricky. The face glass can be ordered in increments of 1/16 of an inch and often that last 1/16th matters. And the size is not the inside diameter of the bezel. You have to subtract a little for how it is mounted. You may have to try a couple close ones to see what is right.
  4. David S
    David S Registered User
    Dec 18, 2011
    7,189
    244
    Brockville, On Canada
    I think the problem is that the bezel appears to be missing, if that is the other side of the hinge I am seeing.
    David
  5. Bill Manders
    Feb 21, 2008
    786
    33
    Prince George
    Harold,
    I do have the pendalum, I had just taken it off as i was moving ther clock around.
    David,
    I also have the bezel, I had tried to fit a flat glass into it and of course the hands hit it, but I do have it.
    Thanks for the fast responses from you guys, and I will likely contact that fellow and see what he has.
    Thanks again to both of you,
    Bill
  6. harold bain
    40,850
    152
    deceased
    If you only need the glass, try Timesavers. You just need a good measurement for proper fit.
    www.timesavers.com
  7. Bill Manders
    Feb 21, 2008
    786
    33
    Prince George
    Thanks Harold.
  8. Jaap
    Jaap Registered User
    Mar 6, 2013
    101
    10
    Hi Bill, When the glass is a little to wide you can grind it down on a bench grinder.
    Please go slow, do not let too much heat build up, otherwise it can crack. Take your time and do a lot of measuring. I have done it myself, when I was winding a clock the glass fell down on the floor.
    Best of luck.
    Jaap
  9. Rockin Ronnie
    Rockin Ronnie Registered User
    Nov 18, 2012
    1,557
    retired educator
    Greenfield, Nova Scotia
    I have a Blackforest time-only clock from the late 1930s with a similar dial/numerals. The hands on yours look a little odd for the period and may or may not be original. Mine takes convex glass and if you are in Canada, Perrin supplies the glass. As you probably know Blackforest changed their name to Forestville after the Second War.
    Ron
  10. wow
    wow Registered User
    Jun 24, 2008
    3,898
    246
    Retired Music Minister
    Pineville, La. (central La.)
    On setting the beat: Is the crutch difficult to move? Sometimes the friction joint where the crutch joins the pallet arbor becomes loose and slips too easily, and once you set the beat and start it running, it slips on it's own and causes the clock to get out of beat. If oil is on that joint, it will slip. Sometimes the arbor must be removed, cleaned, and staked so it cannot slip. Are you sure it is perfectly in beat?
  11. stewey
    stewey Registered User
    Dec 20, 2012
    1,017
    14
    Oshawa, Ontario.
  12. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    68
    It isn't clear that you had this particular clock running.
    If all the parts seem to be in good order it may be that the
    main spring has got dried grease and needs to be cleaned and
    relubed.
    I'm assuming that the movement has clean and properly oiled
    pivots and hasn't been sprayed with something like WD-40.
  13. MINI
    MINI Registered User
    Sep 26, 2012
    296
    #13 MINI, Mar 5, 2018
    hi Bill.. Sorry about being a bit late to the party but I'm wondering if you ever got this movement running and if you ever identified who the manufacturer was? I have the identical movement in a Blackforest Clock from the early-mid 1930's that i need to repair (or replace) one of the chime gears. As can be seen in the photo, those pinions? are bent and causing the chime gear to catch on them and the little mounting 'nipple' on the end is broken off. Apologies if i've use the wrong terminology for those parts. Other than that, the clock worked fine prior to this problem occurring.
  14. shutterbug
    42,675
    1,102
    #14 shutterbug, Mar 6, 2018
    It is a lantern pinion, but the small pins inside are called trundles. There is information on how to replace them in one of the stickies on top of the forum. Here's one that will help.
    MINI likes this.
  15. Uhralt
    Uhralt Registered User
    4,688
    537
    You will also need advice on how to replace the "nipple". The 'nipple is called a pivot and the process of replacing one is called "re-pivoting". You will find may threads dealing with the issue when you search for the term in this forum. It is more challenging to replace a pivot than the trundles.
    MINI likes this.
  16. MINI
    Sep 26, 2012
    296
    Those are both excellent tutorials and thank you for correcting my improper terminology! Now i need to decide whether or not I'm brave enough to attempt this....
    Btw... is anyone able to identify who may have manufactured that movement? I know that the Blackforest Clock Company tended to source their movements from Germany in the '30s but that's as much as i know.
  17. MINI
    Sep 26, 2012
    296
    No one able to identify the manufacturer?
  18. chimeclockfan
    chimeclockfan Registered User
    Dec 21, 2006
    3,967
    189
    Chime clock & gong studies.
    WI
    The Westminster chime clock shown in the original post utilizes a Friedrich Mauthe movement, distinctive by the inverse positions of the chime and strike trains and the brass cylindrical gong block on a pedestal.
  19. MINI
    Sep 26, 2012
    296
    Excellent. That answers the question. Mine is identical to the photo in the first post so then it is a Mauthe movement.
