Recently acquired this bracket clock. The brass movement is stamped on the front plate "FURTWANGEN". The mahogany veneer case has brass inlay, and is 17" in height. I would date c. 1860. Someone will probably be able to ID, but you may enjoy the pics. The movement is held in the case by 3 small iron brackets. The door latches are shaped, the side doors have gothic design fretwork. Larger sized gong mounted on original spruce backboard. The pendulum is missing. Pics to follow.
Most visitors online was 1990 , on 7 Feb 2022
