Big Kundo
Discussion in '400-Day & Atmos' started by etmb61, Feb 28, 2018.
  1. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,481
    167
    Retired Avionics Technician
    Mascoutah, IL
    Sometimes a standard size clock isn't enough and you need something really big. This is my latest arrival, number 19087. It has a 5" dial, a 9 1/2" base, and takes a 7" dome. It's had some major repairs done including some barrel teeth replaced and bushing every pivot (WHY?).
    I'll need to find another pendulum 35 or some parts. I have most of one but it's missing one ball assembly and the hook.
    I guess the date is 1926-28. Looks like plate 1355 but the click spring holes are reversed.
    I've seen several of these for sale, most without the glass. Don't know where you would find a dome this size.
    Now I just have to find a place for it.
    Eric
  2. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,054
    102
    El Dorado, CA
    Nice one. You don't see this one nearly as often as the four pillar model.
    I probably have the ball you need.
    Can you take measurements of the shell halves (They varied quite a bit, year to year, actually) and describe the weight composition and shape?
    Or post a pic of an existing weight.
  3. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,278
    219
    The Woodlands, TX
    Eric, nice example. Made in July-Aug period of 1927 based on the serial number. The deal with Plate 1355 is that it is drawn incorrectly for the serial number found on the illustration. Kundo changed the layout at the time they introduced the pendulum base cup in early 1933. After about SN 54100, the layout illustrated on Plate 1355 is correct. Prior to that SN, the threaded and unthreaded hole position for the click spring tab and screw were reversed from what is shown, exactly as seen for your clock. This is also true for a couple other back plates made at that same time.
  4. etmb61
    Oct 25, 2010
    2,481
    167
    Mascoutah, IL
    It took me over a year and a half but I've finally acquired a pendulum 35 to complete this clock.
    Wayne A likes this.
