• Important Executive Director Announcement from the NAWCC
    The NAWCC Board of Directors is pleased to announce that Mr. Rory McEvoy has been named Executive Director of the NAWCC. Rory is an internationally renowned horological scholar and comes to the NAWCC with strong credentials that solidly align with our education, fundraising, and membership growth objectives. He has a postgraduate degree in the conservation and restoration of antique clocks from West Dean College, and throughout his career, he has had the opportunity to handle some of the world’s most important horological artifacts, including longitude timekeepers by Harrison, Kendall, and Mudge.
    Rory formerly worked as Curator of Horology at the Royal Observatory, Greenwich, where his role included day-to-day management of research and digitization projects, writing, public speaking, conservation, convening conferences, exhibition work, and development of acquisition/disposal and collection care policies. In addition, he has worked as a horological specialist at Bonhams in London, where he cataloged and handled many rare timepieces and built important relationships with collectors, buyers, and sellers. Most recently, Rory has used his talents to share his love of horology at the university level by teaching horological theory, history, and the practical repair and making of clocks and watches at Birmingham City University.
    Rory is a British citizen and currently resides in the UK. Pre-COVID-19, Rory and his wife, Kaai, visited HQ in Columbia, Pennsylvania, where they met with staff, spent time in the Museum and Library & Research Center, and toured the area. Rory and Kaai will be relocating to the area as soon as the immigration challenges and travel restrictions due to COVID-19 permit.
    Some of you may already be familiar with Rory as he is also a well-known author and lecturer. His recent publications include the book Harrison Decoded: Towards a Perfect Pendulum Clock, which he edited with Jonathan Betts, and the article “George Graham and the Orrery” in the journal Nuncius.
    Until Rory’s relocation to the United States is complete, he will be working closely with an on-boarding team assembled by the NAWCC Board of Directors to introduce him to the opportunities and challenges before us and to ensure a smooth transition. Rory will be participating in strategic and financial planning immediately, which will allow him to hit the ground running when he arrives in Columbia
    You can read more about Rory McEvoy and this exciting announcement in the upcoming March/April issue of the Watch & Clock Bulletin.
    Please join the entire Board and staff in welcoming Rory to the NAWCC community.
Best method to set up fusee during reassembly?
woodlawndon
Jan 18, 2017
737
187
Woodlawn, Ontario
I am reassembling a fusee movement on an early dial clock and not being experienced in this type I am wondering the best method to set up. What I mean is: do you wrap all the chain around the fusee barrel or the spring barrel while it's let down? Or is there another method such as a couple of wraps around one or the other to begin.
Hope this is clear, if not I'll try another explanation if required. Thanks.
Don
Jerry Kieffer
May 31, 2005
2,886
522
wisconsin
Don
Don
Assuming this is a typical size clock movement, I wind the chain around the spring barrel and hold it in place with rubber bands. After assembly, I connect the chain to the fusee and apply light tension to the chain. From this point, I remove the rubber bands and space the chain in relation to the fusee and then set original tension before winding.
Good Luck
Jerry Kieffer
Reactions: woodlawndon
SuffolkM
Jun 15, 2020
131
Definitely wind around the barrel (masking tape or rubber bands as Jerry mentions to help keep it in place). If it's a fusee chain then be sure not to introduce any kinks - wind it on under gravity (the chain hanging straight below the barrel as you turn it on, spreading evenly across the width to allow the fusee cone channels to take it up without too much sideways pressure the first time you wind).
Don't forget to tension the spring when you have the clock assembled, just before you begin winding the fusee. Approx 3/4 to 1 turn seems common but it does depend on the spring's condition. If you put too much tension on, the clock will run unevenly, usually too fast towards the 8th day. Too little and the clock may stop early. There's no reason to use lots of extra tension once you've overcome the initial bit of necessary load to get into the linear part of the spring's torque curve.
Have fun! Fusee clocks are wonderful!
woodlawndon
Jan 18, 2017
737
187
Woodlawn, Ontario
Thanks folks, those tips worked well. All together and running well. Just need to see if it maintains time consistently throughout the wind time.
Don
163,536
1,421,046
84,937
daniel.hsu
2,857
Aurora's 15 Ruby Jewel Movements by Greg Frauenhoff
Copyright © National Association of Watch and Clock Collectors Inc (A 501c3 non-profit corporation). All Rights Reserved.
