Most visitors online was 1990 , on 7 Feb 2022
Sals, that is not an easy question to answer. The assortments #1,2,3,&4 offered by Timesavers would be ideal for most common clocks. That’s about $200 for all. Is that what you are looking for?You generally have to use what seems close. If you have a set of bushings, use the plate thickness and the pivot size to find the best fit.
"Best" in what way?Hi,
What’s the best set of bushings for (German/French) chime clocks?
Sorry, a more clarified question. What's the best sizes (KMW) for chiming movements (All countries if sizes correlate?) Now that you mentioned bronze bushings, would they really hurt chiming movements with higher quality chime clocks? Thanks."Best" in what way?
Best material, use brass bushings in brass plates and bronze bushings only where an original bronze bushing is being replaced.
Best bushing system (KWM or Bergeon), I use Bergeon but either is OK in most cases. Bergeon has a larger OD and can clean up a centering error where a smaller KWM was installed. Users preference.
Best brand. I prefer Bergeon bushings made by Bergeon, KWM bushings by KWM etc. Bergeon size and KWM size "made in America" (or elsewhere) can made by anyone and and quality and fit may be OK or inconsistent depending on where the distributor is sourcing the bushings.
Best price. This is not a place to cut corners. Individual bushings are relatively inexpensive.
Best assortment sizes. Don't waste money on stock assortments (my opinion), they usually have sizes that are seldom or never used. I order extras of whatever sizes I need for the clock I'm working on. I now have a pretty good selection of sizes that I use for the kinds of clocks I work on.
Thanks. Where was this thread?You can start with six 20 packs of KWM bushings and do nearly all of what you mention.
I wrote a detailed post about this about 3 weeks (?) back.
Good luck,. Willie X
Nope. You'll be making some yourself. Clocks were wearing out long before there were store-bought bushings. I generally have to make them for winding arbors.An irrelevant question (maybe I worry too much), Does KMW have bushing for every clock of different shapes and sizes?
Is this OD or the pivot sizes?you'll want tiny 6mm, 7mm, 8mm, and 9mm sizes, all of which use the KWM II (2) reamer.
Punches or a ball bearing to expand the bushing?Note that you can rivet any bushing into a broached-out hole, and if you're careful with your tapered cutting broach you can, if needed, press a KWM bushing into it.
There has been a lot of discussion about bronze vs brass bushings. Many of us have observed that bronze bushings tend to cause pivots to wear out much faster. I think this is less likely to happen with hardened pivots. The question that's often asked is, down the road would you rather replace a pivot or a bushing? For ordinary American clocks and lightly loaded pivots of any clock I see no reason not to use brass bushings. In certain cases where brass pivot holes seem to wear out fast, such as certain Hermle 2nd. wheel pivots, it makes sense to use bronze bushings and hard pivots, which is what Hermle apparently is doing for some movements. In most cases the best advice I can give is to follow what the original maker used.Now that you mentioned bronze bushings, would they really hurt chiming movements with higher quality chime clocks?
I remember you saying that. I was thinking the same thing.There has been a lot of discussion about bronze vs brass bushings. Many of us have observed that bronze bushings tend to cause pivots to wear out much faster. I think this is less likely to happen with hardened pivots. The question that's often asked is, down the road would you rather replace a pivot or a bushing? For ordinary American clocks and lightly loaded pivots of any clock I see no reason not to use brass bushings. In certain cases where brass pivot holes seem to wear out fast, such as certain Hermle 2nd. wheel pivots, it makes sense to use bronze bushings and hard pivots, which is what Hermle apparently is doing for some movements. In most cases the best advice I can give is to follow what the original maker used.
If the bushing is a bit longer than the plate thickness you can place one side of the plate on a flat anvil and apply a healthy clop with Mr Hammer to the other end of the bushing, which will squash tightly against the sides of the hole, never to move again. Then you'd broach out the bushing ID to fit the pivot, being careful to leave some uncraftsmanlike slop in the whole assembly. (You do _not_ want to bush to precision tolerances.)Thanks.
In what way do the pivots wear out? I've only seen mushroomed pivots in steel plate clocks. Provided that the pivots are reasonably well polished I don't think that the bushing alloy makes any difference. Note that brass bushings are presumably made of whatever brass alloy that the maker felt like, and they are of varied colors.There has been a lot of discussion about bronze vs brass bushings. Many of us have observed that bronze bushings tend to cause pivots to wear out much faster. I think this is less likely to happen with hardened pivots. The question that's often asked is, down the road would you rather replace a pivot or a bushing? For ordinary American clocks and lightly loaded pivots of any clock I see no reason not to use brass bushings. In certain cases where brass pivot holes seem to wear out fast, such as certain Hermle 2nd. wheel pivots, it makes sense to use bronze bushings and hard pivots, which is what Hermle apparently is doing for some movements. In most cases the best advice I can give is to follow what the original maker used.
Guessing the most precision method is lathe?You do _not_ want to bush to precision tolerances.)
Wait, do you mean .6, .7, etc? because 9mm is huge.6mm, 7mm, 8mm, and 9mm sizes, all of which use the KWM II (2) reamer. Then you'd also want 1.0mm to 1.9mm in increments of 0.1 mm for general use.
I don't think I see any on his website.I use 2.7 mm OD bushings more than any other. You would need 1.8 mm OD for French clocks. Mark Butterworth sells them at a great price. Talking to him would help you decide what assortment you need to start. He sells small quantities also.
You will be using reamers 2 and 3 KWM based on your post #1. I like the variety boxes and end up using the not so popular sizes by opening up the id. when I'm out of the ones needed. Concerning bush height, I have read that if the bush is too short or too long that it could cause uneven pivot wear. I always try to make my work look invisible. I need lot's of improvement however...Should I get the sizes for the reamer 1 or 2?
Do I need this or can I just use the handle the set came with? I use nibbling but I can see how chime clocks require a higher precision bush.You can chuck them into a drill press or a hand vise. A drill press serves as a rather nice bushing machine.
I've noticed that over the months, thanks for mentioning as I was never sure.That's because the plates flex a bit when the mainspring is wound or the weights are hung.
Nice work Willie. I can't see F T-2, but I'm guessing T-3 thru T-5 and perhaps S-3? Looks like you may have replaced some type of soldered Rathbun-type bushings?Can you find the 4 replacement 1.4mm height bushings? They are installed right out of the pack, untouched otherwise.
Thanks. I will DM him then.Nice work Willie. I can't see F T-2, but I'm guessing T-3 thru T-5 and perhaps S-3? Looks like you may have replaced some type of soldered Rathbun-type bushings?
Calvin,
Butterworth does provide a wide range of KWM and Bergeon "American" bushings. I usually source all of my bushings from him. Occasionally I'll order from a supply house if I need to "round up" an order.
Bruce
That’s pretty funny lol. Walks off as a mechanical toy.Bruce, you got it, but T-3 is N-E of the white mark. It's the same movement I posted earlier today with all the solder.
Sal, if you leave a movement running on a block like that, the action of the strike can make it walk off the block!
I hate it when that happens! Willie X
I've seen 1.4mm bushings used in 2.0 mm plates. Hate when that comes across the bench. 1.9 should work okay, especially if you leave them as is and don't alter the "oil sink". If you're not tooled up to machine a taller bushing to size, 1.9 is your best bet, in my opinion.So would it hurt a chime clock (2 mm thick) to use a 1.9 mm thick?
Hey, Willie. Beautiful work. What method did you use to get all that solder off?Just finished this S-T #89.
This will be your most used height for most American clocks. Willie X
If the bushing is shorter than the original pivot hole it will wear out sooner.Does height really matter for the common clock as long as it's not protruding?
It is your dollar and your choice. I prefer to buy the name brand bushings. I have occasionally bought the "American made" equivalent when the name brand was out of stock and never experienced a problem but some here have reported inconsistent sizes or loose fits. If you buy unbranded bushings at least buy from a reputable supplier, and start with a small quantity and see how you like them before stocking up.Now, my only question is if I should get the off brand “American” KWM bushings or the German ones.
I've seen discussions on this forum before on this topic. Too short = reduced contact area = increased tendency to wear. Too long = tunnelling may occur, thereby reducing end-shake. My experience is too limited to advise either way.Does height really matter for the common clock as long as it's not protruding?
I order bushings that are a little taller than the plate thickness and trim them flush. Many clocks do not have "oil sinks" so I trim them off and, if needed, form my own. This reduces the number of different height bushings IO need to stock. But unless you use a bushing machine, mill, etc. triming bushings by hand can be a pain.So the best thing is to use the height shorter than the plate? How thick are T/S American plates usually? Because the bushings are .3 mm shorter than the plates. Bad to use 1.9mm on Herschede 2.5mm plates?
Do you mill the individual bushings on a mill? 1.9mm sounds good for my 2 mm clocks then.I order bushings that are a little taller than the plate thickness and trim them flush. Many clocks do not have "oil sinks" so I trim them off and, if needed, form my own. This reduces the number of different height bushings IO need to stock. But unless you use a bushing machine, mill, etc. triming bushings by hand can be a pain.
No not exactly. I use a Bergeon bushing machine and something called a pivot cutter (1) although I don't know why it is called that to trim bushings flush. Sometimes use a Dremel rose cutter (2) adapted to fit the bushing machine. #3 is an oil sink cutter that I made from a ball end cutter. If you have a mill (I do not) you could use an end mill to accomplish the same thing. When a long bushing is trimmed flush and a new oil sink cut it is often hard to see that the pivot hole has even been bushed from the front side.Do you mill the individual bushings on a mill? 1.9mm sounds good for my 2 mm clocks then.
No. If you try to use it you will probably cut too deeply into the bushing and shorten its effective height. You want something round like RC pictured for you. It can cut a relatively wide, round,shallow oil sink. The tool you describe will cut a narrow, deep cone.The only thing KWM thing I have is "Chamfering" tool. Does that cut oil sinks?
