Bergeon 30402 question (balance screw cutting tool)
Discussion in 'Horological Tools' started by rstl99, Apr 12, 2017.
  1. rstl99
    rstl99 Registered User
    Oct 31, 2015
    274
    Retired and free, with dog
    Ontario, Canada
    I bought some used watch repair tools yesterday and in the pile was a Bergeon box containing a 30402 balance tool cutting tool, with the two cutters. It's in nice shape. There is no manual with it, it's fairly self explanatory, but I can't figure out what is the purpose of the tapered pin that one can screw vertically into the base.
    I'd appreciate someone educating me on this. Thanks.
  2. gmorse
    gmorse Registered User
    7,195
    22
    Retired from Xerox
    Hi Robert,
    That's a balance tack which holds the cock up out of the way whilst the balance is being worked on. It means you don't have to remove the balance from the cock.
  3. rstl99
    Oct 31, 2015
    274
    Ontario, Canada
    Hi Graham,
    Oh I see, yes that makes sense. Thank you very much for clarifying this for me. Time will tell whether I will use this tool or not to shed mass from balance screws (I gather from DeCarle that not all watchmakers favour this approach), but Bergeon tools are always such well thought out and manufactured little objects.
    In the parts and tools I acquired was a box containing 12 vials each containing small washers to add weight to balance screws, so I'll need to educate myself on when to add weight vs when to remove some!
    Cheers,
    --Robert
  4. gmorse
    7,195
    22
    Retired from Xerox
    Hi Robert,
    Adding weight will slow it down, removing will speed it up, but remember that the former is reversible but if the latter removes metal from the screws, and you overdo it, will require the addition of timing washers! Substituting lighter screws is a non-invasive way of reducing the weight. This is separate from poising or temperature compensation considerations.
  5. Dave Coatsworth
    Dave Coatsworth Super Moderator
    Donor NAWCC Member
    Feb 11, 2005
    3,993
    Camarillo, CA
    Not only don't overdo it, but stop and ask yourself why you are removing weight before doing so. Make sure you aren't just compensating for some other fault by removing (or adding) weight. The watch left the factory with a given balance weight and timed correctly. Ask yourself what changed between then and now.
  6. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,866
    watchmaker
    Western NSW, Australia
    It is a good comment.
  7. rstl99
    Oct 31, 2015
    274
    Ontario, Canada
    Yes indeed very insightful and thoughtful comments, I appreciate you both for sharing the knowledge.
    Well I suppose it's nice to have that tool and those washers if/when I should ever need them, and to have a better idea now how and when to use them.
    Thank you again.
  8. roughbarked
    Dec 2, 2016
    1,866
    watchmaker
    Basically, these are factory tools. ie: for people who make watches.
  9. Accutronica
    Accutronica Registered User
    Nov 21, 2016
    553
    disabled
    Texas
    Better to have a tool and not need it than to need it and not have it. That's the way I look at it also.
    Robert
Similar Threads - Bergeon question balance Forum Date
Bergeon Bushing machine bits Horological Tools Oct 17, 2016
Just got a Bergeon bushing machine - what else do I need? Horological Tools Jun 9, 2016
Old Bergeon bushing machine parts Horological Tools May 2, 2016
Bergeon #30600 Horological Tools Dec 30, 2015
Question about Bergeon tool Horological Tools Dec 23, 2006
