Bentima mini
Discussion in '400-Day & Atmos' started by PedroCortes, Aug 13, 2018.
  1. PedroCortes
    PedroCortes Registered User
    Jul 31, 2018
    56
    Hello friends, I have a Bentima nini that I don't know how to unlock the pendulum. I know there is a screw to low but I don't understand how I have to do to release the pendulum without damaging the clock. Here I send you a couple of photos.
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,657
    142
    Aerospace Engineer (Ret.)
    San Antonio, TX
    Bentima is a retailer...the clock was made by Kern and Sohne. The screw in the bottom is usually just unscrewed which will lower the guide cup on the top of the base. That should be enough to allow the pendulum to rotate. Can you also show a picture of the back plate?
    Kurt
  3. PedroCortes
    Jul 31, 2018
    56
    I unscrew and the pendulum is not released.
  4. KurtinSA
    Nov 24, 2014
    3,657
    142
    San Antonio, TX
    I have a clock that is similar to this. There seems to be some corrosion associated with the top of the pendulum...it could be that it is just stuck. The bottom block should fall down through the hole that is in the lower bracket. If the bottom block is not the correct size, it could be hung up there. You could carefully undo the two screws that hold the lower bracket in place...then it should come down...maybe you can then work the lower bracket off.
    Kurt
  5. PedroCortes
    Jul 31, 2018
    56
    I have disassembled the stand. but the thread is longer than the pendulum can lower!
  6. PedroCortes
    Jul 31, 2018
    56
    Is it possible that the thread is longer than it should be?
  7. PedroCortes
    Jul 31, 2018
    56
    when I turn the screw. rotate the entire base at the same time .... Look video.
    This it's a normal behaviour?
  8. KurtinSA
    Nov 24, 2014
    3,657
    142
    San Antonio, TX
    Turn the screw under the base the other direction...you must lower the cup in order to release the pendulum. Even still, the spring could be too long but you won't know that until you lower the cup.
    Kurt
  9. tracerjack
    tracerjack Registered User
    Jun 6, 2016
    1,128
    130
    Female
    Lodi, CA
    From your last photo, the guide cup looks stuck in place. You'll have to check out why. I'd suggest removing the pendulum from the bottom block, and disassembling the guide cup to look for whatever is keeping it from dropping down even with the base.
  10. KurtinSA
    Nov 24, 2014
    3,657
    142
    San Antonio, TX
    Just saw the video...don't use a screwdriver on the fastener. Use your fingers on the larger knob to lower the cup and release the pendulum.
    Kurt
  11. PedroCortes
    Jul 31, 2018
    56
    I'm trying everything and not low. the cup is always as seen in the photo. someone can show me a picture of how it should look ... to get an idea ...
  12. PedroCortes
    Jul 31, 2018
    56
    I finally understood ... what a newbie I am ... thank you for your patience !!
    It was very hard ... you had taxon, the rust has had a great influence on lowering the cup
  13. tracerjack
    Jun 6, 2016
    1,128
    130
    Female
    Lodi, CA
    Good you got it solved.
