Bending flat brass for a click spring
Discussion in 'Clock Construction' started by bytes2doc, Jul 14, 2019.
  1. bytes2doc
    bytes2doc Registered User
    NAWCC Member Sponsor
    Aug 31, 2009
    160
    Physician
    Tennessee
    In Bill Smith’s book on construction of a skeletal clock, he states the click spring is made out of 1/16 brass sheet. Lay it out and cut it down. Then bend into the final shape that has a 1 9/16 radius. No details on how to do that.
    Just how does one go about bending it into a curve with such a radius? I tried light hammer strokes along the edge while clamped into a vise, which does bend it, but the bending is not continuous so it ends up with a bunch of humps.
    Ideas?
  2. gleber
    gleber Registered User
    Jun 15, 2015
    1,878
    235
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    It seems like some kind of roller mechanism even if home-made might do the job.
    Tom
  3. Allan Wolff
    Allan Wolff Moderator
    Mar 17, 2005
    683
    64
    Tulsa, OK
    I like to bend it around a form. A socket set will give you a variety of different diameters to work with. Just clamp the socket in the bench vise to hold it while you bend the click. It will spring back some, so a somewhat smaller radius than the final dimension may be needed. I don't think the exact radius is critical. Just give it a curve that looks good and contacts the click in the correct place.
    Which clock are you building?
  4. bytes2doc
    Aug 31, 2009
    160
    Physician
    Tennessee
    Thanks for the replies and ideas, will give them a try this weekend. Maybe if I cut the stock thinner it will be easier.
    I’ve been working on Bill’s scroll skeleton clock, what seems like forever. I have to leave the project for months at a time and even once for an entire year. The click is something I forgot to do, but when complete, onto the dial and motion works, and final polishing.
    Not sure what I’m going to do about the dial as I only have a mini lathe. I do have a mini mill and thinking of offsetting the material while mounted on a rotary table.
    Thinking about your clock Allan for my next clock.
