LarryAC
I recently restored this, what I think to be, Ansonia Africa clock. The clock was incomplete and in pieces when I bought it. With the help of folks here, I concluded the movement was not original, in part because while there is an alarm wheel on the movement, someone hacked it up to fit but it doesn't do anything - there is no lever for triggering the alarm. Also, the double barrel (mercury?) pendulum that came with the clock would not work with the movement that came with the clock. To try to get the clock at least closer to original, I found an Ansonia Kitchen clock movement with the alarm lever and dial, restored it and have it ready to install. The old pendulum works perfectly and keeps perfect time with this movement.
However, the clock came with only the bell that I think is supposed to work with the alarm mechanism - it's very annoyingly alarm-sounding and I can't believe it was also the gong. I found an old Ansonia spiral wire gong but it might not be the correct size for this clock. In any case, I now have a set of gong, bell, alarm mechanism and alarm trigger. but I have no idea how these should be placed in the case, particularly since some or many of these components might not be true to the original configuration. Does anyone have any idea how these clocks were set up to fit a gong, a bell and an alarm mechanism/movement?
For reference, the first photo is the clock with the movement as I acquired it. the second is after my case/movement restoration with the replacement pendulum. The third is of the gong, bell and alarm mechanism that I have (mechanism and bell came with the clock), and the fourth is of the "new" Ansonia Kitchen movement.
