I just brought this one home today, the movement's very dirty and looks like it needs a bushing or two. I haven't done it before, but I guess I need to learn. Anyway, the only number where the serial number is, is 0. I'm hoping to get some info as to when it was made and why a serial number of 0.
Thanks, Mark
Mark, what appears to be the number "0" is actually the letter "O". That is one of several letter stamps on the back of GB hall clock movements as well as their "Amerikaner" style table and wall clock movements that I have been working to identify. For each of these there is a German horological word that refers to a movement function such as "H" for Hohltreiben (Lantern Pinions), "R" for Reschen (Rack Strike) and others yet to be identified.
If there is a serial number it will be at the bottom center of the back plate right underneath the "P112" pendulum length stamp. If there isn't a serial number, the clock was likely made after 1928 when GB started using date stamps on some movements, in particular their Amerikaner design movements. The date stamps were on the front plates at the right upper corner in most instances.
The label on the case of your clock was used from 1919 to 1932, so it's not much help for dating other than to confirm the clock is post-WWI. I'm not where I can access my GB catalogs at the moment but should be able to identify the model number of your clock, will post that when I have the opportunity.
