• Upcoming updates
Beat setting tool repair.
18,255
3,654
After babying this little Gizmo along for about 25 years, it finally stripped out. :(
I was wondering what path others may have taken to repair/improve this important little fella?i Willie X
KurtinSA
Nov 24, 2014
5,846
619
San Antonio, TX
Never had one of those. But check out what a member made as a substitute:
Kurt
TQ60
Sep 15, 2016
291
23
Madera CA
If only screw bad replace.
If female is bad then take it to a well stocked family run hardware store.
Look or ask for a seft tapping screw just bigger than old one.
Correct one will create new threads in the hole.
Next get a standard screw of same size to use.
In future some oil on screw and insure screw has good quality threads that are smooth.
Wayne A
Sep 24, 2019
1,039
212
Have used various levers where there is an opening. Sometimes use a little blue locktite on the block holder screw and only tighten snug, can use screwdriver slot to move it then. Also made a tool after being inspired by Dell's modified needle nose pliers but I used a cheap pair of needle nose locking pliers. I always look at the block holder under high magnification when making adjustments so I can see just how far it moved.
Wayne
Schatznut
Sep 26, 2020
1,494
809
SoCal
Helicoil?
18,255
3,654
I found that the thread was a regular
#10 - 24 and the female part was all still good. So, a stove bolt and a little washer got me back in business.
This tool is very handy but the materials are a little sketchy. Hopefully it will go another 25 years? Willie X
Reactions: DennyI
Schatznut
Sep 26, 2020
1,494
809
SoCal
So is that custom part TIG or MIG welded? Looks good!
Kevin W.
23,694
763
65
I have one, dont use it, piece of crap, far as i am concerned.
rjdj2000
Oct 22, 2022
257
47
Here is one that probably would of worked for you - McMaster-Carr
Your screw and washer idea should work fine and was that a silver solder job? Looks good, as I can tell it is not mig or tig welded.
18,255
3,654
I wouldn't say that, after using that one for about 25 years. Good design, not so good on the materials, as already mentioned. :) Willie X
Kevin W.
23,694
763
65
As a machinist pretty sure we could make a better one.
18,255
3,654
Yes a better one could be made, for a price.
The problem is that people try to use this little tool to turn a tight post. It is not to be used as a hand vise. Just loosen the screw and lightly snug it back down, adjust as necessary and your done. There is no need to tighten the tension screw.
Reactions: Ken M
Schatznut
Sep 26, 2020
1,494
809
SoCal
Willie has it exactly right - and trying to tighten the screw further once you've got it in beat is almost guaranteed to throw it out of beat.
Dells
Oct 18, 2019
1,066
344
In the cotswolds UK
I found the tool useless but maybe the modern ones are different, I have modified a pair of old snap on pliers.
Dell
180,081
1,570,922
54,367
shaimerej
911
3,090
