Bazeley and Harding spherical clock
Discussion in 'General Clock Discussions' started by Jase, Sep 2, 2019.
  1. Jase
    Jase Registered User
    Sep 2, 2019
    12
    Midlands
    Hi
    I have a Bazeley and Harding spherical clock , it went in for repair and service and has come back lovely however I put the balls on and it started working straight away and dropped a weight every couple of hours , it then dropped two together and seemed to then miss one , it then stopped 5hrs later . After turning the wheel to remove the rest of the weights it started ticking again yesterday it is keeping perfect time , but the wheel hasn’t turned and no weights dropped yet . Can anyone please advise as to why this is ? Thank you in advance any advice would be appreciated as I know nothing about this clock
  2. bruce linde
    bruce linde Technical Admin
    7,268
    960
    oakland, ca.
    is there a reason you're asking here instead of where it was serviced? and... what was repaired?
  3. Jase
    Sep 2, 2019
    12
    Midlands
    Hi
    It has had a new escapement and was serviced , the balls were stopping randomly and then it stopped, the repairer was going to come and look at it, but as explained when removing the balls it started to tick again and is keeping perfect time , however the wheel isn’t turning. I have asked on here as I know nothing about this clock and wondered if anyone could advise if I have to wind it up via the wheel or is it just the weights that wind it up , any information about the clock and workings of it would be appreciated thank you
  4. bruce linde
    7,268
    960
    oakland, ca.
    i don't know that clock and am in the middle of something that precludes going out on the web to look for photos (which you should always include, btw! :)).
    that said, i don't count a clock as fixed and running until it's run for at least a few weeks and/or winding cycles... to make sure everything is as it should be.
    escapements are tricky... and this one sounds a little trickier than most. i think you and/or your repair person need to stare closely as the escapement as it's running to see what might or might not be happening.
    note: i just fixed (crossed fingers!) a grandfather clock where the @#$@%#$^ problem turned out to be a part that looked like it was screwed solidly in place but still managed to rock ever-so-slightly... causing the clock to strike incorrectly, or not at all.... the most subtle little thing but enough to cause a major headache.
    hopefully someone will come along who knows those clocks, but still think your repair/service person needs to walk you through the care and feeding of your clock, and make sure you understand how it operates.
  5. Uhralt
    Uhralt Registered User
    4,974
    609
    See here for a picture: A brass 'Spherical Weight Clock', Harding and Bazeley, - Jul 02, 2014 | Dreweatts Donnington Priory in United Kingdom on LiveAuctioneers
    The auction has ended, so the link may be provided here. It seems to me that the balls just wind the clock. If more than one ball falls at a time-or none, there must be something wrong with the way the balls enter the wheel. Maybe the clock is just not standing level? The clock has a platform escapement, therefore running is not affected as long as there is still power on the mainspring.
  6. Jase
    Sep 2, 2019
    12
    Midlands
    Here are some pictures
    54A66086-D5AE-43F9-88C5-E548BC92DD4B.jpeg FAA51257-2FBC-4952-9B70-33CE6166A279.jpeg 5ABB9D19-5188-44F3-A8D6-E8B6760EA3DF.jpeg A28B4127-AAA2-40BC-A0F8-845A0F04183D.jpeg
  7. JTD
    JTD Registered User
    Sep 27, 2005
    7,915
    570
    Welcome to the board.
    You've just got your clock back from being serviced and it clearly isn't working properly. Please don't fiddle with it, take it back to whomever did the service (or get him to come round) and see what is happening..
    These are expensive clocks and do not work in the usual way of other clocks. You need to have your service man explain to you carefully how the clock works and also put right anything that it not functioning properly (although, as Uhralt says, it may just be as simple as the clock not being level).
    Let us know how you get on.
    JTD
  8. Jase
    Sep 2, 2019
    12
    Midlands
    Thank you for the advice, I was just hoping to get some understanding and information about the clock and hopefully the repairer can fix , I was just making sure it wasn’t supposed to be behaving in this way
    Thank you
  9. bruce linde
    7,268
    960
    oakland, ca.
    keep in mind that even if you know how a clock is supposed to work, each one is unique and might have certain characteristics or traits (or even repairs) that require being treated a certain way... and the person who just went through it and serviced it is the best person to advise.
    let us know what he says, and post some video of it running once it is again (upload video to youtube and then copy and paste the url into a message here)
  10. new2clocks
    new2clocks Registered User
    NAWCC Member Sponsor
    Apr 25, 2005
    2,550
    306
    Pennsylvania
    Yes, please post video of the running clock! Would very much like to see it.
    Regards.
  11. bruce linde
    7,268
    960
    oakland, ca.
    also wanted to add 1) welcome, 2) cool clock!, and 3) it's incredibly flattering that people seem to think us regulars know everything about every clock. o_O
  12. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    4,967
    170
    Devon
  13. Uhralt
    4,974
    609
  14. bruce linde
    7,268
    960
    oakland, ca.
    one weight drops every two hours and forty minutes? yes... that seems intuitive. :cool:
  15. bruce linde
    7,268
    960
    oakland, ca.
    there are no videos of this thing to be found on youtube... i think it's time!
    please take some video when you get it running, upload to youtube, and then copy and paste the url into a post here so we can see it in action.
    thx!
  16. Jase
    Sep 2, 2019
    12
    Midlands
    We will get a video for you tomorrow and post it
