Clock Barrel
Discussion in 'Parts Wanted' started by jonboy, Nov 3, 2019.
Tags:
  1. jonboy
    jonboy Registered User
    Jan 25, 2015
    40
    SERVICE TECH. RETIRED
    RINGGOLD GA.
  2. Kevin W.
    Kevin W. Registered User
    22,558
    379
    What is wrong with this barrel?
  3. Uhralt
    Uhralt Registered User
    4,912
    599
    A couple of teeth are missing which could be replaced. There is a good article about that in the "How to" section. If you want to replace the barrel we would need the complete dimensions and the teeth count.
  4. jonboy
    Jan 25, 2015
    40
    RINGGOLD GA.
    I am in need of a mainspring barrel for a old LFS wallclock
    The dimensions and teeth numbers are as follows.
    # of teeth 82
    inside dia. of drum 36MM
    outside dia of drum 39MM
    heith of drum including teeth 22.50 MM
    Diameter of teeth 42.40
