shutterbug is correct,many times you will see wear marks on the inside of the cap,i have never heard of a depth tolerance for spring barrels,spring should be just below the the cap recess,some times you may need to stake the cap to the barrel edge as i have seen many barrels oversized and beat up because repairer didn't know how to install the cap correctly,some think a hammer and punch are needed??most caps are slightly over sized and designed to snap or pop into the barrel recess,i use a set of soft jawed slip joint pliers
