I have a 3 battery Barr clock...Two questions;
1) It swings about 20 swings before it "resets" is this normal ?? ( keeps good time )
2) Again I dont know the proper name for it but the two spring steel looking contact arms ...each has like a small bead on it that actually makes the contact...The one bead is almost gone all together...is this an issue and if so how hard would it be to replace...it looks like its just pressed into the spring steel
Thank you
Thank you
