Balance Staff Replacement on Columbus 18s
Discussion in 'Watch Repair' started by Absilon, Sep 12, 2017.
  1. Absilon
    Absilon Registered User
    Dec 19, 2014
    30
    I will be attempting my 1st balance staff replacement on an 1890 Columbus Model-3, 11 Jewel movement.
    This is it here: https://pocketwatchdatabase.com/search/result/columbus-watch-co/173818
    I will be using my K & D Inverto Delux, No.18 Staking Set.
    I have watched every video and read everything I could find over the last several months and have a decent idea of what is involved. I have so far successfully repaired several non working pocket watches which are all running fine now, with the exception of one 1910 Waltham Grade-625, Model-1908, 16s Pocket Watch that losses 2 minutes each day, but I will re-visit that one soon.
    I have been unable to find a parts & materials catalog for Columbus. If anyone here has a pdf that would be great!
    I have some questions that I hope this wonderful community can help me with.
    For starters, which staff do I need and are they available?
    Is this a friction fit or riveted staff?
    Let me know if you need me to remove the staff and take some close-up photos.
    Can one tell the difference between friction fit and riveted staffs by looking at them?
    Can one tell the difference between single and double roller staffs by looking at them?
    Also. Is this a good movement to start balance staff work on? If not, I have other movements that need staffs including:
    1908 Waltham Riverside Grade Model-1894, 12s, 19j
    1916 Illinois - Grade-69, Model-6, 18s, 17j
    1889 Rockford Grade-68, Model-8, 18s, 11j
    1879-80 Waltham Model-1877, Grade-Broadway, 18S, 7J
    1896 Waltham - Model-1890, Grade-Y, 6s, 7j
    1952 Bulova 17AH
    and some other higher grade watches that I will staff after getting some practice.
    I have been learning so much and having lots of fun in the process. I really love this hobby. balance staff
    Thank you in advance for your input and advice.
    Have a great day!
  2. 18k BPH
    18k BPH Registered User
    Aug 18, 2016
    26
    Absilon,
    The only Columbus Watch material catalog pages are the following:
    [​IMG]
    [​IMG]
    [​IMG]
    Also, I found the following mainspring information:
    [​IMG]
    I hope this helps!
  3. Dave Coatsworth
    Dave Coatsworth Super Moderator
    Donor NAWCC Member
    Feb 11, 2005
    3,994
    Camarillo, CA
    The info sheet that I have shows 3 different Columbus 18-size staffs:
    [​IMG]
  4. MrRoundel
    MrRoundel Registered User
    Dec 28, 2010
    821
    Real Estate Broker on hiatus
    So. Cal., USA
    I have the same list as Dave C., and maybe one other, but it is illegible. :-( It's interesting that there is so little information on Columbus parts. I find part numbers for mainsprings, but that's about it. There must be a Columbus specialist out there who can help. Good luck.
    As far as which watch to restaff first, you might want to consider that Waltham 12s Riverside, especially if it's a friction staff. The friction staff is driven out by design, and is not held to the balance by a rivet. Do yourself a favor, learn now to remove a riveted staff with a lathe, not a K&D or other drive-out method. I have a few pocket watches laying around that after driving out the staff using the K&D, I now require a slightly larger staff. Were they like that before? Hard to know. However, best practice is to undercut the rivet on a lathe, in order to avoid enlarging the balance arm. Good luck.
  5. Bila
    Bila Registered User
    Jan 22, 2010
    431
    #5 Bila, Sep 13, 2017
    If you can find a friend with an early "Waltham Horological School" staff kit you will have a staff for the early 18s Columbus models in pivot sizes ranging from .11-.14 size (if they want to part with them of course:)), also on some of the slightly later 18s Columbus watches a 18 size Elgin #857 staff is interchangeable. So once again, you will need to remove the staff and measure it's dimensions.
Similar Threads - Balance Staff Replacement Forum Date
Balance staff replacement Watch Repair Aug 2, 2017
American PW Need help locating a replacement balance staff for Elgin Pocketwatch :) Watch Repair Feb 7, 2014
Mechanical WW balance staff and wheel replacement Watch Repair Jul 17, 2013
American PW Elgin 18S balance staff replacement question Watch Repair Aug 13, 2012
American PW Riveted Balance Staff Replacement Watch Repair Jun 7, 2010
