American PW Balance staff info needed.
Kevin W.
23,173
565
Can someone help me identify which staff i need for this watch.
It is a Elgin, 18 sz, 15 jewels.Grade 317, Serial number is 15015031.
Thanks for your help.;)
Kevin W.
23,173
565
Thanks Doug, much appreciated.:p
Kevin W.
23,173
565
bkerr, one pivot is broke i will measure every thing i can before i cut the old one off.Thanks for the heads up.
RJSoftware
Apr 15, 2005
8,510
137
Loxahatchee, Florida
Vert.
I wish somebody would give me details on how to precisely measure the staff dimensions.
I only have a veneer caliper and a 10x loupe -so far. But the caliper does have sharp blades to measure with. (Measures in .001" -inch).
I can see measuring the diametors. But how does one measure the lengths?
I seen Bkeer's post of more elaborate measuring tool but not sure how it would be used.
RJ
ben_hutcherson
Jul 15, 2009
3,180
389
Kentucky
Rather than measuring, which would be difficult with a broken pivot, here's a quick rule of thumb:
If the serial number is under 3,000,000, you probably need the old style(short) staff. If the serial number is over 3,000,000, you probably need the new style(long) staff.
Short vs. long hub is easiest to determine by comparing the pictures of your current staff with the pictures available in the material catalog(which is available online). The difference between the two is pretty obvious even without magnification.
Chances are pretty good that you need a new style, long hub staff. This is the most common type, and in fact will commonly just be called simply an 857 when ordering(the others will specify O.S. for old style and S.H. for short hub).
166,934
1,454,685
87,193
Hullah
