Balance Pin why?
nuno
May 1, 2011
218
11
Hello, i have buy this watch movement. I view have a depose. But when i see back balance have a long brass pin. Do you know why?
roughbarked
Dec 2, 2016
1,383
744
Your photos aren't the clearest but this is unusual. Is it actually connected to anything? I'd be trying to remove it as the watch is unlikely to run well with it there.
The movement looks like an AS or maybe a Larga. (both the AS anyway)
Dr. Jon
Dec 14, 2001
8,078
2,411
New Hampshire
I can guess at two things this pin for this pin to do:
1) As placed it limits the movement of the regulator. I do not beleive this is its purpose because this can be done more simply
2) it is reduce the chance of the balance spring getting tangled when exposed to a magnet. I have had such tangling happen.
John Matthews
Sep 22, 2015
4,709
2,763
France
The photographs are unfortunately not clear. The 'bar' is positioned between the overcoil and the rest of the balance spring. To assist understanding and provide feasible explanations it is necessary to have an answer to the question asked in the post #2 above ...
Unless of course, someone actually knows what it is!
John
Dr. Jon
Dec 14, 2001
8,078
2,411
New Hampshire
If to keep teh overcoil in place there is and has been a much better way with a "shelf" on the bottom of one of the pins such that it can be rotated away for placement. This form looking like a thin and fat pin has been in wide use.
All of these assume it was put there by someone who ahd an idea of what they were doing.
jboger
Jan 7, 2019
1,059
403
67
The consensus seems to be that the pin is to hold the overcoil in place. One would think this would be handled by the stud screw on the balance cock. This screw is very typical for U.S. watches--sans pin. On U.S. watches, one can adjust the height of the stud by sliding it up and down before tightening down with the screw. I've adjusted this height by eyeballing the flatness of the balance spring before tightening in position. Perhaps this pin is a guide so the stud is adjusted to the right elevation, thus taking [some of] the guesswork out of where to tighten down with the screw? Whatever the reason, it seems redundant and unnecessary to me.
John
Appa69
Apr 3, 2022
415
319
44
The pins look very loose in the first picture. This may explain why it's there, but why not just tighten the pins?
gmorse
15,752
4,860
Hi Appa69,
The index pins should also be parallel, which these aren't at the moment, giving rise to possible unwanted variations of rate in positions. If the spring doesn't sit at the right level and centrally between the pins, it's a matter of manipulating the stud and/or the spring itself, a seperate issue.
John Matthews
Sep 22, 2015
4,709
2,763
France
I assume you mean for non-parallel pins acting a non planar spring - as is likely to be the case where there is an overcoil.
If my understanding is correct, is it the case that 'unwanted variations' will also be present if the spring coil is not in the same relative position between the pins throughout their arc of rotation (checked when the balance is stationary)? Again, if my understanding is correct, I think this would lead to greater variation and it would also apply to a planar spring.
John
gmorse
15,752
4,860
Hi John,
Certainly, it doesn't matter what the spring configuration is, if there's any possibility of the portion of the spring between the index pins moving axially in different positions, (due to staff endshake or gravity for instance), the effective spacing between non-parallel pins will vary and hence may affect the rate.
Appa69
Apr 3, 2022
415
319
44
I understand that the pins shouldn't be "tight", but I was led to believe that both pins should contact their side of the spring at all times and that any air gap was undesirable.
Dr. Jon
Dec 14, 2001
8,078
2,411
New Hampshire
The spacing of index pins is an adjustment. The pins should be parallel. Their separation varies with what the adjuster is trying to do.
My view remains that the mentioned pin is not to locate the over coil but to prevent tangling when the watch is put into a de-magnetizer. This was something wrist watch wearers had done fairly regularly when refrigerators with magnetic door closures came into use.
John Matthews
Sep 22, 2015
4,709
2,763
France
Jon
To be clear do you mean that the pin is not normally present, but has been inserted temporarily as a precursor to the watch being demagnetise?
John
Dr. Jon
Dec 14, 2001
8,078
2,411
New Hampshire
I believe the pin was there permanently. The pin is fixed at one end to the balance cock . It should not touch anything except when the balance spring is dancing around in a de-magnetizer.
183,956
1,606,738
55,964
S.K. Hawkins
3,190
Watch case by Kent
Top Bottom
