I have a Bailey Banks and Biddle pocket watch with a movement market “American Standard.” As I understand it, BB&B did not manufacture the watches themselves, so different movement and cases will appear with their name, but despite this, they had a high quality reputation. I have this heirloom watch, with only the family history of the original owner, but no real perspective on how common or rare this watch is. It runs easily when wound, but I haven’t been able to figure out how to adjust the time, and I’m hesitant to use much force in any way that might damage it. Any insight will be much appreciated.
Gold case and chain. The pin at the end of the chain is stamped 18ct. The inside of the case on the movement side is marked 18K, with the serial number 64831, which is just the serial number for the case I believe. The inner case cover over the movement has three lines of markings. The first is “1$3” (it could be an 8 instead of the 3 (see photo). The second line is “64831,” and the third line is “23.” The movement is marked on four separate lines as follows:
Safety Pinion
Adjusted
American Standard
3067291
The outer edge of the movement is is decoratively marked Bailey Banks & Biddle. Philadelphia
There appears to be an adjustment labeled S or F.
The watch face and jewel appear to be original and intact. (See photo) Each of the hands moves as it runs. I have turned the dial to wind, but haven’t discovered any obvious method for setting the time. The watch is in what appears to be great condition despite having been used for several decades by its original owner. Again, an insight or context on this watch will be greatly appreciated.
Safety Pinion
Adjusted
American Standard
3067291
