Baeurle Peerless Movement
Discussion in 'Clock Repair' started by Bill Cann, May 28, 2019.
  1. Bill Cann
    Bill Cann Registered User
    Mar 26, 2019
    30
    I have a Bauerle Peerless movement that runs well but the strike seems like it is missing something. There is no spring on the hammer, so it strikes once and bounces loudly a couple times after that. There are two pins that a spring could be attached to but not sure an extension spring would work, but maybe a hefty torsion spring might. Attached a couple pictures. Hoping someone can fill in the gap.
    Thanks for any help.
    Bill
  2. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,368
    400
    Science teacher, writer
    Lancaster, Ohio, USA
    The pin that sticks out of the hammer shaft looks like it was engaged by a simple spring made from a piece of heavy piano wire that staked into the opposite plate. These break off without much provocation. If there was such a spring you'll find its remains staked into the rear of the front plate. I would add that there are better designs for hammer springs, and a light coil tension spring hooked to wherever you can hook it would probably do a good job. But if there was a simple staked one-wire spring for the hammer and you want to reproduce it, just drill a tiny hole next to the broken-off spring in the front plate and stake in a substantial piece of piano wire or pivot wire.
    M Kinsler
  3. R&A
    R&A Registered User
    Oct 21, 2008
    4,203
    107
    I don't think this one has a spring. You adjust the pickup with the screw on the side of the hammer. The bounce is from it being to close to the gong.
