Bad Adjusting Wheel
Discussion in 'Clock Repair' started by grasshopper, Aug 22, 2016.
  1. grasshopper
    grasshopper Registered User
    Sep 3, 2013
    169
    Retired now work part time as an Adjunct Professor
    Wells, ME
    #1 grasshopper, Aug 22, 2016
    I gave myself a promotion last week and now consider myself a "Semi-newbie" which is an upgrade from my previous "newbie" rank. Anyway here is my issue… I just began working on an F Kroeber movement (its mine). I ran it through the Ultrasonic cleaner for the first time and will begin bushing tomorrow. After cleaning I did an examination of the movement and discovered that the wheel which turns the slow/fast adjusting bar is in pretty bad shape (I don't know the correct names of the slow/fast adjusting bar or the wheel....maybe I shouldn't have given myself that promotion after all). My questions…What can be done about this wheel? Is there anything "I" can do myself (I do own a mini-lathe but have no idea how to cut a wheel).
  2. Willie X
    Willie X Registered User
    12,774
    985
    I think you have a Seth Thomas movement there. Shouldn't be to hard to find a junk movement with the parts you need.
    An adjustable pendulum is a good way to go. ST sold a lot of clocks that had adjustable pendulum and rate adjustment mechanisms.
    FYI, this part is broken because people, for some unknown reason, try to wind up the rate adjuster.
  3. shimmystep
    shimmystep Registered User
    Mar 5, 2012
    4,101
    81
    Cambridge, UK
    On your lathe you could turn a piece of brass rod to the correct diameter, drill the correct sized hole through it, part if off and file the teeth out of what you have. A most enjoyable coupla hours filing away on easy to file material.
    Or find a junk movement as willie suggests.
  4. shutterbug
    43,987
    1,314
  5. emhitch
    emhitch Registered User
    Mar 17, 2009
    97
    medical device design engineer
    pittsburgh, pa
  6. lpbp
    lpbp Registered User
    NAWCC Star Fellow NAWCC Life Member NAWCC Member
    Aug 25, 2000
    2,922
    Shutterbug: That is for an upper adjuster, not sure if it could be modified to work, as has been mentioned try and find a Seth Thomas. As to why they break, it's caused by people running it to the end of the adjustment, then trying to force it farther.
  7. grasshopper
    Sep 3, 2013
    169
    Wells, ME
    The clock movement plate is stamped very clearly F Kroeber so I am sure it is a Kroeber... although maybe ST made movements for Kroeber at some time. Since I am a "semi-newbie" with a new lathe I am seriously considering trying to make a wheel as shimmystep suggested, but maybe it is over my head. Rather than using an adjustable pendulum as suggested I am trying to get myself in the habit of keeping as much of the original configuration of the movement as possible. Thanks for all the help....if it wasn't for this forum I would never have continued with this enjoyable rewarding hobby.
  8. David S
    David S Registered User
    Dec 18, 2011
    7,201
    246
    Brockville, On Canada
    Grasshopper why don't you at least try and fix it. I would attempt this in a heart beat, even if it took a couple of attempts to get it right.
    The gear as it is, is non functional.. You have a lathe, you can make a blank and then with a jewelers saw or files or both shape the teeth.
    Once you have the old wheel pressed off you can place it over the blank and trace the good teeth, rotate / index and trace the rest.
    Nothing to loose and good learning for when you simply can't find a donor.
    David
  9. shutterbug
    43,987
    1,314
    The part I referenced should provide the gear that you need. Easier than making one.
  10. David S
    Dec 18, 2011
    7,201
    246
    But not as much fun :)
    David
  11. shimmystep
    Mar 5, 2012
    4,101
    81
    Cambridge, UK
    Totally the 'have a go' outlook I am a huge fan of :thumb:
    Just having a go, even if you don't necessarily need to, brings such rich learning experience in this fabulous field.
    Grasshopper, the below small pinion for stop works, I made cutting the blank on the lathe and the rest was files and wet and dry paper. But ya gotta have a the time!
  12. dad1891
    dad1891 Registered User
    Feb 28, 2014
    602
    Denver, Colorado
    Filed from a blank...........that looks downright professional.
  13. grasshopper
    Sep 3, 2013
    169
    Wells, ME
    Thanks all...great advise! I think I am going to try making the wheel first and if I fail buy the wheel as Shutterbug suggested.
  14. lpbp
    Aug 25, 2000
    2,922
    Yes Seth Thomas did make movements for them at one time.
  15. shimmystep
    Mar 5, 2012
    4,101
    81
    Cambridge, UK
    Look forward to seeing it :)
