Most visitors online was 1990 , on 7 Feb 2022
Loose pallet stone?The wandering upper trace is still there. Not sure what causes that.
That was my thought. That's why I replaced the pallet with one from a spare 554. But I get the same semi-random 'dropped' points in one of the traces with the new one. It's not as bad as the old one, but it's still there.Loose pallet stone?
Because I'm a fumble-fingered amateur?Which watch? Would be the first question.
Have you demagnetised the hairspring? Have you specifically hand washed the hairspring?
Why haven't you adjusted the beat better? The two lines should be closer together.
