I picked up another watch from Ebay, a movement and case I'd been wanting for a while. Got it for cheap because it was 'wound tight'. Opened it up, checked first to see if the balance staff was broken. Nope! Hmmm. So why doesn't it run?
So, I look closer at the balance. Something not quite right....
Well, THERE'S your problem!!! I took off the balance cock for a better look. Oy. What a mess!
When I got it, the regulator was pushed all the way to Slow. Looking at the hairpspring, I noted that even with the stud removed from the cock, several coils are touching. Lifting the stud, I noticed that these coils stick to each other.
So here's my hypothesis: guy gets watch. Watch runs fast, because coils are touching. Guy swings regulator over to 'Slow', but hairspring is trapped by regulator pins. Hairspring gets crushed between regulator and stud. Watch stops. Guy tosses watch in drawer.
Time passes, and the watch finds its way to me.
I guess this will test my ability to true a hairspring. Well, I'm nothing if not foolishly overconfident!
