I normally work only on my own watches, and I prefer manual winding vintage watches, so I have almost no experience with autowinders. A friend asked me to "just clean up" his Rolex Oyster Perpetual Cal A 296/645 from 1953. After cleaning (and a new mainspring), it runs fairly strongly (amplitude about 285-290 dial up, fully wound), all positions within about a 25 sec per day window. I decided to wear it around a few days before making a final tweak to the regulator. After 24 hours, amplitude was less by maybe 5 degrees, and after 48 hours, it was off by about 15 degrees. Power reserve is 41 hours, so it was obviously getting some winding, but not staying fully wound. After 72 hours, amplitude was 235 or so, and after 96 hours amplitude was around 190. At 110 hours, at 5:40 a.m., it stopped. I gave it a few twists (the case, not the crown) to get it started and took the dog for a 15 minute walk, which caused the watch to run for about 3 hours. When I hold the watch up to my ear and rotate it back and forth, I can hear the rapid clicks of the ratchet on the center wheel (it is unidirectional) and then the slow clicks of the ratchet on the first intermediate wheel. Based on this, and some calculations I did, I think about 2 hours a day of brisk walking would keep the watch wound. Unfortunately, I am mostly at the computer or workbench all day.
Holding the watch vertically with the back off, and the watch fully wound, the weight of the rotor will not move the winding mechanism. If I push the rotor slightly with a piece of pegwood and then let go, it springs back. Of course if the rotor has some kinetic energy when it engages, it might be possible for it to move the arbor. I considered whether the bridal was sticking too much. I lubricated it with 8217, and when manually winding the watch it does not seem to stick. The watch just keeps winding with no noticeable change in the feel. So I am thinking even if the autowinder delivered enough energy to keep the watch going indefinitely, would it be constantly at the low end of the power reserve? That seems less than ideal.
Any thoughts? Maybe this just not the right watch for a couch potato. I have some questions about lubrication of the autowinding mechanism, but this is already too long.
