Austin Steele Tall Clock
Discussion in 'Wood Movement Clocks' started by John Teeter, Apr 4, 2011.
  1. John Teeter
    John Teeter Registered User
    NAWCC Fellow NAWCC Member Golden Circle
    Jan 31, 2001
    56
    I have a wood movement tall clock with the dial signed "Austin Steele". The movement is a standard 30 hour Leavenworth. I have found that Austin Steele purchased movements from Mark Leavenworth at various times.
    Has anyone seen another Austin Steel dial or label?
  2. rmarkowitz1_cee4a1
    Nov 26, 2009
    5,169
    865
    I have not seen another.
    Couldn't you just imagine that would be the name of some detective from a 1930's radio drama.."Austin Steele, Private Eye" or something like that?
    Just have to comment. What a FABULOUS folk art dial (looks like the first pic is post-cleaning and some judicious inpainting/restoration).
    Howzabowt pics of the whole clock?
    RM
  3. John Teeter
    Jan 31, 2001
    56
    I had Kathi Edwards clean it up for me. It did not have a case so I am using one that I had.
    What is nice is that Mark Leavenworth was in Waterbury and the dial is also a Waterbury style, but maybe unique. I did find that an Austin Steele owned a woolen mill in Waterbury. I imagine that he was trying to get into the clock business which was growing at the time.
  4. Peter A. Nunes
    Peter A. Nunes Moderator
    NAWCC Fellow NAWCC Member Sponsor
    Mar 3, 2006
    1,655
    Restorer of antique clocks.
    Rhode Island
    #4 Peter A. Nunes, Apr 4, 2011
    John, I think your Austin Steele dial is mounted to a William Leavenworth movement, not Mark. Mark used two upper dial mounting studs, William only one. In both cases, they were threaded into the upper stiffener, then pinned inside the front plate. Good, well lit photos of the movement would be helpful to illustrate this obscure point.
    This is the only example I have ever seen.
