auction purchases
harold bain
40,851
168
72
Re: auction purchaces
Nice finds, Ken. I have a very similar Cincinnati time recorder, same short pendulum movement.
Ken Knox
Feb 1, 2007
265
Brooklyn, Iowa
Visit site
Thanks Harold. That is a well built clock. My Webster mainspring winder isnt big enough to fit over the winding arbors so properly servicing the movement will have to wait till I figure out another method.
Ken
Anteater
New Member
Dec 21, 2008
Frankfort, IL USA
That Long Case is a beauty. My grandfather had a similar clock when I was a child - very wide case that makes the clock appear to be shorter than it is. Any idea on the history?
Cheers, Ant.
Ken Knox
Feb 1, 2007
265
Brooklyn, Iowa
Visit site
I have no history on the long case clock. Yes the case makes the clock look much shorter than it is. It is 8 feet 3 inches tall. With the hood removed I was lucky that it fit in the back of my Jeep grand cherokee along with my other purchaces. I had several onlookers while I was loading it. The movement hadnt been serviced in years so that was the first thing I did. It now keeps perfect time.
Ken
uncletom
Feb 23, 2006
24
looks like a pretty nice portico clock as well must have been a good auction,Tom
Burkhard Rasch
Jun 1, 2007
4,861
169
64
Twistringen
The portico is marvelous,mine is more humble than that one with the ornament in front.And they have best quality mvmts.Congrats!!
Burkhard
harold bain
40,851
168
72
Ken
Ken, when working in these clocks, I wind it up, tie off the springs with wire, then remove the anchor and let it slowly unwind into the wire. Just have to be careful that both sides are equally unwound. These clocks are a neat change from the time and strike movements. They are definately well built to withstand factory life.
Ken Knox
Feb 1, 2007
265
Brooklyn, Iowa
Visit site
Thanks for the Tip Harold. One question though....in servicing the spring. How do you get it recoiled and secured again for instalation?
I purchaced these clocks at the semi anual Tom Harris clock auction in Marshalltown, Iowa. They always have interesting clocks. Just going to the preview is a treat in itself.
Ken
harold bain
40,851
168
72
Ken, I made a 1/2 inch chuck fit into the chuck on my Webster (squared off the end of it), so I can unwind like any other loop end spring. Just have to be very careful, these springs have a lot more power than the common 8 day springs found in most clocks.
Topic related ad experiment
