ATO ATO ANTICLIMATIC
Discussion in 'Electric Horology' started by no1bradd, Sep 19, 2018.
  1. no1bradd
    no1bradd Registered User
    Apr 24, 2010
    29
    Hi Can i get a wiring dia for a ATO ANTICLIMATIC i rewind the coil ,but do have the wiring for the this .
    Thanks Bill
  2. JTD
    JTD Registered User
    Sep 27, 2005
    7,633
    509
    You might do better posting this in the electric horology section, where the electric experts lurk.
    Maybe a moderator will move it for you.
    JTD
  3. no1bradd
    Apr 24, 2010
    29
    Hi That will be fine Bill
  4. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,479
    167
    Retired Avionics Technician
    Mascoutah, IL
    Does it have a circuit board under the base?
  5. no1bradd
    Apr 24, 2010
    29
    Hi No the circuit is on the back .
    Thanks Bill
  6. etmb61
    Oct 25, 2010
    2,479
    167
    Mascoutah, IL
    Can we have a peek at it? It could be helpful. I've only worked on the Kundo version but Junghans is probably similar.
    Typically if there is a separate circuit board the coil will connect at two points and the battery at two others. Polarity of the coil is important as it both senses and drives the pendulum.
  7. no1bradd
    Apr 24, 2010
    29
    Hi There is the model hope you can get a wiring for this .Where does battery goes :???::???:
    Thanks Bill (rewired the coil 40k )
  8. etmb61
    Oct 25, 2010
    2,479
    167
    Mascoutah, IL
    Here is a link to a similar clock.
    1962 Junghans ATO Electronic Clock
    The schematic linked in the first post looks like what you have. Assuming you have the coil wound like the schematic, the blue wire is the center tap between the two coils, the red wire is the drive coil, and the green wire is the sense coil.
    Can you read the number on the transistor? The older germanium transistors were usually in metal cans like this one from a Seiko clock:
    or glass. Yours looks like a TO-92 (plastic) package so it could be a replacement.
    Eric
  9. no1bradd
    Apr 24, 2010
    29
  10. no1bradd
    Apr 24, 2010
    29
    The transistor is BC 548B but i still do not have the wiring for the clock ?? were does the battery go :???:?
    Thanks Bill
  11. no1bradd
    Apr 24, 2010
    29
    Hi ,I got a AC125
    Bill
  12. etmb61
    Oct 25, 2010
    2,479
    167
    Mascoutah, IL
    As the circuit was designed, the "+" battery end connects to the red wire from the coil and "-" end connects to the terminal between the transistor and the capacitor.
    Physically, the battery was probably 4 AA cells wired parallel in a paper box mounted in a bracket under the base of the clock.
    Eric
  13. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,652
    141
    Aerospace Engineer (Ret.)
    San Antonio, TX
  14. no1bradd
    Apr 24, 2010
    29
    praezis likes this.
  15. no1bradd
    Apr 24, 2010
    29
    Hi ,Thanks all you have done, i am waiting for the AC 125 to come before i get the clock running .
    Bill
  16. no1bradd
    Apr 24, 2010
    29
    Still won,t go, got a AC125 transistor try it but it still won,t go ANY HELP :???::???:
  17. no1bradd
    Apr 24, 2010
    29
    Got it going at last . Hooray
  18. JTD
    JTD Registered User
    Sep 27, 2005
    7,633
    509
    I'm happy for you, but are you going to let us know what you did to get it going?
    JTD
  19. no1bradd
    Apr 24, 2010
    29
    Rewired the coil
    Thanks Bill
  20. JTD
    JTD Registered User
    Sep 27, 2005
    7,633
    509
    Well done, and thanks for the information.
    JTD
