Atmos help
Discussion in '400-Day & Atmos' started by wow, Aug 14, 2019.
  1. wow
    wow Registered User
    Jun 24, 2008
    3,656
    182
    Retired Music Minister
    Pineville, La. (central La.)
    Got this one in. Out of beat. Got it in beat. Put one drop of synthetic oil on front minute arbor bushing. Seems to have low power. The chain from the bellows is slightly loose but there is power. I don’t know if I has enough power because it runs a few minutes and the hand almost clicks into position but does not. Touch it gently and it clicks into place. I’m a dummy with these, any help appreciated. Here’s photos:
    880D60F4-A1F8-4E3C-A964-A15155C84046.jpeg 75334FEB-8968-42B6-8B93-45E161E04CEB.jpeg F3D5B137-7C72-4E82-A535-7C682F7C3284.jpeg
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,343
    122
    Retired Avionics Technician
    Mascoutah, IL
    I'm pretty sure me movement should be dry past the first wheel pivots.
  3. wow
    wow Registered User
    Jun 24, 2008
    3,656
    182
    I only put one drop on the minute shaft pivot. The rest is dry. Do you know about the chain?
  4. Ed O'Brien
    Ed O'Brien Registered User
    Nov 30, 2009
    556
    Retired, and now full-time clock repairs.
    Winter Park, FL
    No oil on the Atmos except at mainspring and intermediate wheel. Loose chain is a problem.
  5. etmb61
    Oct 25, 2010
    2,343
    122
    Mascoutah, IL
    One drop of oil is one more than there should be.
    I see the chain is loose. It won't wind like that. You'll need to remove the bellows to sort that out.
  6. klokwiz
    klokwiz Registered User
    Feb 4, 2009
    1,271
    36
    WRENCH
    Annapolis, MD
    hi,
    the chain definitely should not be loose. it rides back and forth with the movement from the bellows motor in rear drum. typical issue would be a flat bellows meaning it is not expanding or contracting with temperature change which provides chain movement to wind mainspring. you will need to determine the following: 1) is chain hung up due to mainspring and or spring winding click malfunction. 2) is the bellows working and or is the chain hung up in bellows area. If you apply pressure on the train will clock continue to run? this is tricky since this pendulum will run or seem to run for 15 minutes. and is subject to the minutest movements of clock.
    Joe
  7. klokwiz
    Feb 4, 2009
    1,271
    36
    WRENCH
    Annapolis, MD
    here are photos from my recent atmos showing chain assy with motor removed. I would not change anything on clock until you resolve loose chain. Joe
    motor assy removed.jpg motor assy top view.jpg chain spring assy motor removed.jpg motor chain spring assy top view motor removed.jpg
  8. new_hampster
    new_hampster Registered User
    Aug 3, 2006
    95
    Any slack in the chain indicates a problem. The back spring should keep all slack out of the chain. Check that the chain is free on the pulley as it enters the bellows housing. It's also possible that the spring on the chain pulley has come loose or has been stretched.
  9. wow
    wow Registered User
    Jun 24, 2008
    3,656
    182
    Thanks, gentlemen. Great photos and info. I removed the bellows cover and found the chain unhooked. The pin was inside the bellows. I carefully got it all back together and it is running. We’ll see how long. Will report back. I am posting a photo of it after I got the pin in. I also am including a paragraph from Mike’s clock shop which suggests a drop of oil on the minute arbor bushing. That’s why I oiled that bushing. Is this no longer considered a good practice?
    E85AC019-5F13-4391-88FE-1B350B02BA71.jpeg E88A790A-5FA1-41B8-9FF5-4394359430FE.jpeg
  10. klokwiz
    Feb 4, 2009
    1,271
    36
    WRENCH
    Annapolis, MD
    Hi, glad you found the issue. I think though you have to determine the proper depth for the chain spring and backing plate. If I recall there was a depth measurement shown on one of the atmos repairer sites on how to determine length of chain. the one I pictured had several links dangling from the retaining pin. You also need to make sure the chain is not twisted as it goes thru to the winding wheel at main spring barrel to prevent binding of chain.
    Joe
  11. etmb61
    Oct 25, 2010
    2,343
    122
    Mascoutah, IL
    Of course you can oil anything and I'm sure Mike has his reasons, but LeCoulter's documentation states only oil the winding arbor pivots, the intermediate wheel pivots, and the mainspring. There is so little power available that any parasitic loss, such as the viscosity of the oils or the tiny dust particles they attract, can influence the operation of the clock. Also, lubricants always migrate to where you don't want them. If you put oil where it isn't needed you kind of force yourself to service the movement more often than it would have needed if left dry. If it won't run dry I would suggest you have some other problem.
    My thoughts.
    Eric
  12. wow
    wow Registered User
    Jun 24, 2008
    3,656
    182
    Thank you, gentlemen. It’s running great and keeping good time. Fixing the bellows and setting the best did it.
  13. wow
    wow Registered User
    Jun 24, 2008
    3,656
    182
    The customer picked it up Saturday after it ran perfectly in my shop for several weeks. He was extremely proud to have it running. It was a retirement gift of his now deceased father. Very happy ending.
    Now.......I have another Atmos exactly like it in my shop that will not stay running. I have set the beat and checked everything I know to check. There is good power supplied to the escapement. It just will not keep running. Where do I go next? I need suggestions from you experts please.
  14. Ed O'Brien
    Nov 30, 2009
    556
    Winter Park, FL
    If in beat, with a good bellows, properly positioned fork, culprit possibly a dry mainspring.
  15. TQ60
    TQ60 Registered User
    Sep 15, 2016
    202
    Madera CA
    We oil the center shaft very carefully with a thin wire dipped in oil, the film of wire brushed onto the front of the interface where the coaxial shafts are.
    Your clock could have many minor things dragging it.
    Assuming you have read details for proper working on these, if not stop and do more learning.
    All gears need to be spotless and jewels in pallets need to be polished as well.
    A good microscope is great help.
    In your case first clean and oil spring and examine rest of clock with magnifying glass or microscope.
    Leave movement alone unless it looks dirty.
    Put back together and test run.
    Count the bars or dots to determine rotation.
    Start it with about 270 degrees and see if it gains.
    It should gain to over 360 in not too long a time, if it gains maybe good but if not full cleaning.
  16. matthiasi
    matthiasi Registered User
    Dec 3, 2010
    334
    Clock Repair & Restoration
    Kelowna
    Klokwiz - Nice to see Someone using gloves when working on these...
    Seen way too many an Atmos or fine Swiss Neuchatel with fingerprints or worse on them.
