I have a 540 in the shop. The owner decided to wind in manually as the bellows was getting weak. When he did this he way over wound it causing the pin to fall from the winding chain. From the Jerry Jager stuff I've read, he tells you to replace it in the link it came from. Is there a measurement like for the other calibers to check the tension? Thanks in advance.
