Are there Sources for curved Spring Washers
Discussion in 'Clock Repair' started by ChrisCam, Jan 2, 2019.
  1. ChrisCam
    ChrisCam Registered User
    Dec 9, 2017
    1,118
    19
    England
    Hi, where you need enough friction for the arbor to turn the minute wheel but not enough so the clock can be adjusted the usual method is to use a curved spring washer to exert sufficient friction between the arbor's sholder and the wheel. Are such washers available as the other option is to make one by hammering brass, which at face value seems for a 1cm hasher terribly fiddly? Any ideas?
  2. wow
    wow Registered User
    Jun 24, 2008
    3,358
    130
    Retired Music Minister
    Pineville, La. (central La.)
    #2 wow, Jan 2, 2019
  3. Snapper
    Snapper Registered User
    Nov 30, 2014
    233
    15
    Lincolnshire, UK
  4. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Thanks for both of your replies, snapper and WOW. It may be that what you have shown me would suffice. i will order and investigate. on the remaining Black Forest movement I have there was no washer, the other had one. The washer that was there looks spring steel about 3/4 of an inch long and sits on the shoulder of the arbor. Just thinking out loud but if you had to make such a tension washer could you make one from an old 12mm main spring. Could it be worked i.e bent into a satisfactory form, if so just using pliers (hand grips) or possibly heat?
  5. Uhralt
    Uhralt Registered User
    3,343
    298
    Yes, old mainsprings are a good material to make those springs. I prefer not to anneal them and just bend them with pliers. I shape them with a grinding wheel. For the central hole I stake a little dimple and use a Dremel grinding wheel to grind off the top of the dimple. Then I use a diamond round needle file to enlarge the hole. Sometimes you need to file a square hole to fit the arbor.
  6. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    That's brill thanks for that!
  7. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,582
    197
    Science teacher, writer
    Lancaster, Ohio, USA
    I'm afraid I'm not fluent in British. What is a "1cm hasher?"
  8. wow
    wow Registered User
    Jun 24, 2008
    3,358
    130
    I’m trying to “hash” that out too.
  9. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Typo meant 1 cm basher (hammer job) apologies!
  10. kinsler33
    Aug 17, 2014
    2,582
    197
    Thank you. Now that it's in correct British, could someone translate it into Ohioan or some related dialect? My own efforts thus far have yielded, "one-centimeter hammer job," which still isn't entirely clear.
    Mark Kinsler
  11. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Do the best you can for a duffer.(lol)
  12. shutterbug
    39,932
    582
    He's describing using a hammer to create a washer, Mark. Of course he should be thinking hammer and ball bearing ;)
  13. Hudson
    Hudson Registered User
    Jul 19, 2010
    168
    7
    Spicewood
    dapping set.jpg Dapping blocks can be used to make cupped/curved washers
    THTanner likes this.
  14. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Hammering a brash washer on a ball bearing?
  15. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Thanks a good idea. If you hit a segment of old clock main spring would it work this way as opposed to pliers?
  16. shutterbug
    39,932
    582
    You'd have to anneal it first, probably. Experiment with it. BTW, you'd hammer WITH the ball bearing, not ON it ;)
  17. THTanner
    THTanner Registered User
    Jul 3, 2016
    2,226
    117
    Carson City, Nevada
    old brass main springs would be ideal to start with - but they are almost impossible to find
  18. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Can you clarify the use of a ball bearing. i.e how do you hammer with such a small bearing, you could use a punch on the bearing on the metal which in turn is over a concave anvil block or dapping block??
  19. kinsler33
    Aug 17, 2014
    2,582
    197
    To make a small cupped washer, brass or mild steel, place a non-cupped (flat) washer on a block of soft wood. Place a hardened steel ball, presumably meant for use in a ball-bearing assembly, atop the flat washer. The hole in the washer will keep the ball from rolling away. Then, using a hammer, apply a substantial blow to the ball. This should yield a cupped washer. Suitable balls of 1 centimeter or smaller should be available at your local bicycle repair shop.
    Note that a steel washer made in this way would have to be heat-treated in some manner to be reliably springy if it was heavily compressed. Brass washers would likely be work-hardened by the process, so I don't know how those would behave.
    I'm not sure how one uses that 'dapping block,' which has languished in Timesavers' clearance listings for years.
    Mark Kinsler
  20. shutterbug
    39,932
    582
    That's it, Mark. Soft wood is best. You could also drill a small hole, not too deep, and put the rim of the washer over it.
  21. kinsler33
    Aug 17, 2014
    2,582
    197
    And instead of a steel ball you can use whichever punch is handy. This excellent method allows you to drive the punch right through the stretched-out washer, which will then be inextricably stuck onto your punch.
    M Kinsler
    I think I finally got the fool thing off, after which I got up out of the chair and went to find another washer and a steel ball.
  22. ChrisCam
    Dec 9, 2017
    1,118
    19
    England
    Thanks Mark, It depends on the nature of the washer needed. The one I have come across exerting friction to a time wheel is oval and presumably made from spring steel. I would be minded for such a washer to use pliers and a segment from an old main spring after looking at the alternative suggestions here. Should a smaller round washer be needed then possibly your method would be worthy of attempting. Thanks for the ideas guys.
    Regards
    Chris
