Appealing to the Experts
Discussion in 'European & Other Pocket Watches' started by CluelessClock, Sep 11, 2017.
  2. Welcome to the new home of the NAWCC Message Board
    We are glad to see you have found us Guest. If you like what you find here, please let your friends know about us.
  1. CluelessClock
    CluelessClock Registered User
    Sep 11, 2017
    7
    #1 CluelessClock, Sep 11, 2017
    I've recently come into possession of two of my grandfather's old pocket watches and know nothing about them, one of which is below.
    I would be extremely grateful for any information or direction as to obtain more specifics. I have tried the old internet, but have exhausted my limited capabilities & am at the end of my rope. Eventually I think I would need to get them insured so I need to know as much about them as possible as to not be taken advantage of when calling in the policy. Many thanks in advance for any and all help.
    Here are the details as I've been able to gather them. I'm going to post as many detailed pictures as I can in the hopes that someone sees something important!
    Has NO identification on the watch face
    Has a door covering watch face and two doors over the movement on the rear.
    First cover says (???): Flgtron LGH 14467
    and on the bottom near the hinge: 21142
    Second door's outer engravings are (to the best of my ability to read):
    B. Saval a St. Jmier (I know St. Imier is popular with watch makers, but to me, it looks like a J)
    No 21142
    Hands (hole)
    Patent Lever (hole)
    Full Jewelled
    Inside this cover are the watch gears etc, but as far as I can tell, no markings with the exception of the S-----F spring adjustment...
    I've read as much as I can find, I'm assuming B. Saval was an independent watch maker in St. Imier, but I don't know anything other than that...
    The watch has a small winding tool that works, winds the movement and sets the hands. However the hour hand is loose and flops about a bit.
    So many thanks again! Thanks for reading, thanks for any help, thanks for letting me continue this search!
  2. CluelessClock
    Sep 11, 2017
    7
    Thank you MartyR for your help in placing this post where it belongs!
  3. CluelessClock
    Sep 11, 2017
    7
    Does anyone happen to have any information about this mystery watch?
    Should I post more/different pictures or am I missing something important?
  4. Ethan Lipsig
    Ethan Lipsig Registered User
    Jan 8, 2006
    1,190
    No one has provided any information about your watch because it is one of many thousands of similar watches that were anonymously produced in Switzerland, assembled of parts often made by farmers in the winter. The name on your watch is probably that of the assembler, wholesaler, or retailer. The information you provided about your watch is about as much information as likely to exists, apart from identifying the movement layout style.
  5. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,767
    I am in agreement with what Ethan said.
  6. CluelessClock
    Sep 11, 2017
    7
    My thanks to you both for at least providing the answer that there is no answer... Frustrating to find a dead end instead of information, but I'm appreciative to the forum and its members.
  7. Les harland
    Les harland Registered User
    Apr 10, 2008
    732
    Are there any Hallmarks on the inside of the back cover?
    You would be looking for a bird or bear (Swiss Silver) or a moon and crown (German)
    The Online Encyclopedia Silver Marks, Hallmarks & Makers Marks should list them
    http://www.925-1000.com/
  8. Lychnobius
    Lychnobius Registered User
    Aug 5, 2015
    330
    I think we can at least suggest a date, which is probably between 1850 and 1870.
    What does the dial (face) look like? It is unlikely to yield any more precise information, but we might be able to establish (for example) whether the hands are likely to be original or not.
    Oliver Mundy.
Similar Threads - Appealing Experts Forum Date
Need experts to help to identify an very old interesting Vacheron Constantin!! European & Other Pocket Watches Feb 22, 2014
Unknown movement has stumped the only expert I know European & Other Pocket Watches Dec 3, 2013
“Small VERGE Fusee movement signed LeRoy c1790. Hi where are the French experts? European & Other Pocket Watches Feb 2, 2013
One for the "Experts"; when did Jewels first start to appear in Pocket Watches? European & Other Pocket Watches Sep 14, 2012
