I picked this up at an auction a while back. It has a 30-hour, weight-driven brass movement that is unsigned; there is no label on the case, although it appears that there was one inside at one time. It is a very nice walnut case, 29.75 inches tall, with burl walnut side pieces and a carved decoration above the door. The door opens from the right (hinges on left). Note the two brass screws at the top on either side that appear to have always been there. The upper glass is new, the lower glass old, with a lithograph stencil on the glass. It appears that the glass has never been out of the door. There is an old metal dial that has been with this clock a long time, judging from the paint loss around the screw holes at the bottom, but of course it should not be screwed in. It also does not fit the door glass (top of dial is covered by door frame, lower edge of dial does not extend beyond the door midbar.
I'm guessing a homemade clock from the mid-1800's, but the presence of a label imprint is inconsistent with that, unless the backboard is "recycled".
Anybody seen this before?
