Anybody collect Accutrons?
Discussion in 'Wrist Watches' started by Mike Kearney, Mar 3, 2001.
  1. Mike Kearney
    Mike Kearney Guest
    We've had the WW board up for a while now, and no one (as I recall) has has said much about Accutrons or earlier electric watches. Like some others, I consider most electric watches to be efficient and boring. But I like Accutrons and have a couple. Does anyone else?
    Mike
  2. Mike Kearney
    Mike Kearney Guest
    Mike
  3. Tom Huber
    Tom Huber Registered User
    Dec 9, 2000
    2,993
    145
    Track & cross Country Coach
    Indiana PA
    I have had a couple of Accutrons, but ended up selling them. I got tired of puting batteries in them. My belief is the one big mistake that Bulova made was that there was not a shutoff switch put onto the watch. Many of the modern quartz watches can be shut off by pulling out the stem. This way the battery does not run down while it is in the drawer. I've also been told that Accutron batteries may not be mfg in the future due to them being mercury batteries. I've talked to others that have tried the conversion kit to use a regular nickel cadmium battery. Their comment was that it did not work well. Anybody else tried the conversion kit for an Accutron? Tom
    [This message has been edited by Tom Huber (edited 03-03-2001).]
  4. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    51
    Calgary, Alberta
    Tom, You may be aware that some of the later 218 based series of Accutrons actually did have a circuit breaker which opened when you pulled the crown into a setting position. I am not sure that Accutron would have been spared onrushing technology, regardless of how many whistles and bells were added. Look at the original Accuquartz! One major failure was the cost to build that watch at a time when LEDs could be produced fo pennies, and sold for a few dollars. I have 9 Accutrons/Accuquartz, all but one of which actually run. My favorite is the one my late father gave me in 1961. Looks and runs like NEW, (after being rebuilt many times). I'd like to know more about the WEIN CELL mentioned by Chuck. What can you tell us, Chuck?
    Doug S.
  5. I have a Bulova Factory Bulletin that claims 1.5 volt batteries can be used safely in Accutrons that are properly adjusted. I have been using the 1.5 volt batteries without any problems for several years.
    Have any of you had problems using the 1.5 volt batteries?
    Larry
  6. Greg Davis
    Greg Davis Registered User
    Nov 29, 2000
    2,868
    Manager of Engineering Programs
    Washington state
    Personally, I don't collect Accutrons. However, I have run acriss two so far (a 214 I bought for about $1 and a 218 I picked up for $24). I've sold one (the 214) and am preparing to sell the other. I've sold quite a number of display cases and new old stock leather bands for them too. As far as I am concerned, I don't see what all the fuss is about, but don't mind a bit that people are willing (nay, eager) to pay me a good deal more for the Accutron stuff than I pay for them. It helps to fund some of my other watch related activities.
    As for electrics in general, I do have a couple in the collection... but I don't think much of them. They are, on the whole, less accurate and less attractive than the jeweled watches. That aside, they were a relatively short-lived breed, and probably have come collectability for that reason if no other. This, I believe, also explains the hubub around Accutrons.
    - Greg
  7. Steve, Once again you have made this perfectly clear to me. Love the drawing. However, is it possible that the doorhandle downshoots of the opposing diotomy flectors on the crustacion of the osillating wheels could be counteracting with the oppossors. Thus the phasing readjusts the index forks, pre-closing the belamide trances? This could happen. Regards, Marty
    [This message has been edited by Marty Rougeaux (edited 03-04-2001).]
  8. Dave Haynes
    Dave Haynes Registered User
    Sep 12, 2000
    1,297
    I've had several Accutrons the best one being
    a 214 "Astronaught"; a great watch. The 214
    railroads are great too. I've never been
    too keen on the spaceviews; it's like peeking
    into the back of a radio. Not at all as
    interesting as a crystal backed automatic.
    I've found the 218s to be troublesome and fragile. Am I alone here? I finally stopped
    wearing Accutrons because the buzz drove me
    crazy at night.
    Regarding the mercury batteries: Your government at work. I went down to buy a
    battery for my Pentax Spotmatic. It
    cost $13 and is going to die in a year.
    From $3 to $13, that's real progress.
  9. To clarify just a little, the Bulova website doesn't discuss diodes, it just states that the 1.5 volt batteries can be used - as I said, I have a printed factory bulletin to the same effect.
    One other minor point of clarification, the 214 battery number for 1.5 volts is now 387S.
    And finally, Dave - although I agree that my government spends way too much time trying to protect me from my own idiocy and from sometimes imaginary dangers, mercury really is very toxic, so I don't mind seeing the mercury batteries go away......
    Larry
  10. Mike Kearney
    Mike Kearney Guest
    Regarding the power saving feature of later Accutrons, the series 221 had it. The 221 was a tonneau shaped movement of the early '70s. It had two coils, like the 218 and the 214. If you pulled out the setting stem it disconnected the battery for storage. On the 218, at least the ones I have, the hands stop but it keeps on humming, using up the battery.
    But if you have a 230 series, also an early '70s model, beware, as the technical letter says 'do not keep in setting position as this rapidly drains power cell'. The 230 used the same power cell as the 218, but it only had one coil.
    Anybody know if there's a battery saver on the 224?
    Earlier this year I went to get a 218 battery at the local hardware store. I was surprised to find a dusty old 343 1.35v mercury cell still in the package. I bought it, put it in a 218, and it's still working fine.
    Mike
  11. Tom Huber
    Dec 9, 2000
    2,993
    145
    Indiana PA
    I realized after I had made my post that I didn't mean a nickel cadmium cell. What I had meant was a regular 1.5 cell. What my watchmaker friend had referred to as the conversion kit must be the add on with the diode. Anyway, I'll still continue to obtain them when the price is right, but I would not seek them out. I just consider them too much bother to have as a wearable watch. Tom
  12. Dave Haynes
    Sep 12, 2000
    1,297
    Chuck:
    I think that the whole deal, mercury,MTBE
    etc. is all about money. The greenies are the
    willing shills for the companies who become
    wealthy. Out here in California it has become
    a fine art, supporting MTBE in gas when it presents an environmental hazard beyond the scope of imagination.
  13. Tom Huber
    Dec 9, 2000
    2,993
    145
    Indiana PA
    Re: wein cell. I have seen the air cells advertised and used in hearing aides. They are sold with a removable cover across the back of the cell. Remove the cover and pop it into the hearing aide. The cover is supposed to extend the life of the cell while in storage. Of course, with a hearing aide, one is not worried about a life of over 10days to 2 weeks. Tom
  14. doug sinclair
    Aug 27, 2000
    14,364
    51
    Calgary, Alberta
    Chuck,
    I think you said that mercury cells are still sold in Canada? Uh! Uh! Same problem here, UNLESS you are able to find a jeweller with NOS batteries, the same problem exists here. If you know a secret I don't know, it would be nice if you would share it.
    Doug S.
  15. Gents,
    I'm confused. The silver 1.5 volt cells work fine most of the time, are easily avaiable, cheap, and most important, safe.
    You go to a lot of trouble to get a mercury cell, put it in customer's watch, years go by, the customer takes out the now-leaking battery, some 2 year old swallows battery and suffers nerve damage. Likely? No. Possible? Yes. If it were your 2 year old, would you care:???:?
    I guess it's your choice, but I fail to see the rationale for taking the chance when a perfectly suitable alternative is available......
    By the way, mercury vapor lamps contain mercury, modern fluorescent lamps do not.
    Larry
  16. Mike Kearney
    Mike Kearney Guest
    Larry, your point is well made. We could debate whether watch batteries leak all that often, and in general they don't, but there's no doubt that mercury is bad for people, that the silver oxide batteries are safer, and that most of the time, 1.5v won't cause a tuning fork movement to run fast. And even if it does, all that's needed is to adjust the index mechanism to factory specs. At least in most cases. That and a cleaning and oiling and the Accutron will probably run fine (assuming batteries are replaced as needed) for another 2 to 25 years.
    Which raises the delicate issue of why, (this is addressed to most collectors of virtually all types of watches) given our appreciation of these little mechanical marvels, why don't we get them serviced? Maybe that's a subject for another thread.
    Mike
  17. Chuck,
    Your comments reinforce my contention that the use mercury batteries should be avoided.
    I will give you the benefit of the doubt and assume that the "you are a fool" comment is not intended to call me a fool for suggesting that mercury batteries could pose a danger to children. My comment above specifically referred to leaking batteries, and having seen Accutron movement ruined by battery leakage, I am not imagining.
    I stand corrected on fluorescent lamps, which do contain a small amount of mercury.
    Yours, Larry
    [This message has been edited by Larry Jones 98326 (edited 03-06-2001).]
  18. Mike Kearney
    Mike Kearney Guest
    While you both make good points, I believe a discussion of the actual toxicity of a single mercury battery, or of a landfill containing a representative number, is, if not moot, then at least pretty far off track of the purpose of the board. I would ask please that we voluntarily table the discussion of whether mercury batteries are a problem, and concentrate instead on if or how their lack of availability affects us as collectors.
    I do believe that workshop safety is a concern, and that there are some hazards working with and around watches. Some are more obvious than others. I'm going to start another thread on one of those hazards right now.
    Mike
    [This message has been edited by Mike Kearney (edited 03-07-2001).]
