Any movement as Synchron A43RA running at 220V, 50Hz?
Discussion in 'Electric Horology' started by Roberto39, Jan 27, 2017.
  1. Roberto39
    Roberto39 New Member
    Jan 27, 2017
    When in USA I bought a beautiful wall clock, running at 110V, 60Hz. Brought to Europe, I have of course some problems. The voltage is 220V: ok, just a transformer can solve. But the frequency is 50 Hz. From USA I bought a "high-quality inverter", powered by 12 Vdc, with output 110 Vac and frequency "stable and sinusoidal," says the producer, at 60Hz. But the clock does not keep time, it goes a bit 'forward. The movement is a Synchron A43RA-6-76 0020. In your opinion, can I find (and where) a replacement movement, running at 220Vac 50Hz? Should I just change the movement or the whole assembly? Or should I operate (but do not know how: I do not have the circuit diagram) on the inverter? I would like to see it work well: it's too nice! Thank you for your patience and your suggestions: only here I can find an answer.
    Pictures:
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    You might post a picture of the motor. Many of these have motors that
    come in 60Hz and 50Hz types.
    Your inverter is not intended to run a synchronous clock. It is intended to
    be used with transformer equipment that would over heat with a square
    wave inverter.
  3. harold bain
    Donor NAWCC Member
    39,946
    There should be a motor available in the correct voltage and frequency. Yours was made in 1976
  4. ElectricTime
    ElectricTime Registered User
    Sep 28, 2002
    190
    you either have to find a frequency stable 60Hertz source (which would be quite expensive) or a 50HZ motor.
    The motor is made by Hansen mfg - you could contact them and ask who has purchased a 50HZ version of this motor and purchase them from this firm. As hansen has a large minimum order.
  5. Snapper
    Snapper Registered User
    Nov 30, 2014
    111
    Lincolnshire, UK
