Any info on this old clock?
Discussion in 'General Questions' started by Kathykate, Apr 18, 2017.
  1. Kathykate
    Kathykate New Member
    Apr 18, 2017
    I went to see my cousin who is clearing out his father's house and we came across this clock. I took a few photos of it, we know nothing about it. I think the outer casing is metal, it is a heavy item. Would anyone have any information about it which I could pass on to him?
    There is a date inscribed on the back, plus numbers. Also something scratched into the inner bottom of clock.
    Size was approx. 8 inches high x 7 inches wide (doing that from memory so very approximate).
    Regards
    Kate
  2. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,603
    It appears to be a French marble timepiece probably late 19th C.
    It should have a pendulum if it hasn't been lost.
  3. JTD
    JTD Registered User
    Sep 27, 2005
    3,863
    12
    Welcome to the board, Kate.
    As Jonathan says, your clock should have a pendulum. Have a good look inside the case and see if it has got down at the bottom or stuck in corner. Even if it has got lost, replacements can be bought quite cheaply.
    The scratched marks are no help really, they were probably put on by a repair man, although the date of 19/5/05 gives you an idea of when at least one service was carried out.
    These French movements often had no maker's mark.
    JTD
  4. Kathykate
    Apr 18, 2017
    Thanks all for replies, will pass on to my cousin. Think if the date refers to a service, it would have been done in 15/5/1905, not 2005, as my cousin had never seen the clock before, it was buried at the back of a cupboard.
  5. JTD
    JTD Registered User
    Sep 27, 2005
    3,863
    12
    Yes, of course, I meant 1905, 2005 didn't even occur to me...............it's called being old!
    JTD
  6. Kathykate
    Apr 18, 2017
    On picture number three, it shows the underneath of the clock with something scratched into the white inners. It looked like the outside was made of a different material to the inside, which looked like rough white stone. I didn't think to get a better photo, but you can just see where the outside material is and the inside material. So did they just put the more expensive marble on the outside, and use cheaper stuff inside for weight/strength? What is the inside made of?
  7. Willie X
    Willie X Registered User
    8,005
    25
    Yes, all the various parts are held together with a type of very fine mortar slurry called 'slip'. Sometimes there are metal fittings or anchors that are attached with the slip too. All this weather's well and will last indefinately, or until it falls off the mantle. ☺
Similar Threads - info clock Forum Date
Wooden bracket clock info needed General Questions Feb 26, 2017
mantel clock info General Questions Feb 19, 2017
Clock info General Questions Feb 14, 2017
Karl Lauffer Grandfather Clock Info General Questions Feb 12, 2017
Any info? Junghans alarm function table clock General Questions Feb 6, 2017
