Any Idea What This Is? Is It a Clock?
Discussion in 'Electric Horology' started by expeditionhiker, Jan 3, 2020.
  1. expeditionhiker
    expeditionhiker Registered User
    Jan 4, 2017
    46
    This looks really interesting. Does anyone know what it is? Why are the numbers on the face backwards?
    79126694_10219178027454485_2053967985034395648_o.jpg 78674044_10219178027854495_3377940706847883264_o.jpg 78843149_10219178027574488_4376455809291255808_o.jpg 79036429_10219178028374508_4053245424184590336_o.jpg
  2. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,039
    95
    El Dorado, CA
    At first I thought it might be a Barbershop clock, but the numbers are not reversed. It looks like the hour hand has simply been replaced by a dial, given the orientation of the numbers. If it's purpose built, I don't know what it's for. Was there a pointer ot outer dial cover of any kind?
  3. wbranko
    wbranko Registered User
    Feb 1, 2004
    401
    I am going to SPECULATE here, since there are few responses. This looks to me like a master clock based on some kind of countdown system. This might have been useful in a school based on start times that fluctuated? There appears to be something in the mechanism under the dial and movement that looks quite a bit like a Telechron rotor. If so, it would indicate that his items might be from the late 1917s to about 1930? Or maybe it was modified then? Wish I could help more, but a really neat clock!!! Have you been able to see if there is a manufacturer stamped on the movement behind the dial?
  4. mxfrank
    mxfrank Registered User
    Oct 27, 2011
    138
    I'd need some better photos of the mechanism, but my guess is that this is some sort of home brew self winder. The dial seems to rotate clockwise, and time could be read if a fixed pointer was attached to the case or painted on the glass at a the 12 o'clock position. The chapter ring is divided into five minute intervals. So it's kind of a tape measure dial. What's interesting is that you have small numbers 1-12 on outside of the chapter ring, six hours offset. I suspect that the gadget that's at the six o'clock position is a switch or maybe a mechanical actuator. And that some sort of contact or trigger could be screwed onto the rim of the dial, similar to a Simplex time clock (see photo). The numbers are six hours offset because this actuator is at the bottom of the dial, not the top. What I think happens when this contact is made is that the motor (that is a motor?) rolls up the chain, lifting the weight. Whether this energy is what powers the clock, or whether it operated another mechanism, I don't know.
  5. shutterbug
    42,769
    1,125
    That sounds feasible. It's an interesting clock. The ladder chain is involved somehow in that motor mechanism. Is it running? I'd love to see it in action.
  6. mxfrank
    Oct 27, 2011
    138
    If it's any help, the motor is a Bodine Electric with a right angle gearbox, similar to this model NSE-12RH. The motor probably turns 5000 RPM, and the gearbox gives at least 10:1 reduction. It's 1960's vintage.
  7. Jmeechie
    Jmeechie Registered User
    Dec 8, 2010
    182
    14
    Hi,
    I’m going to go with some sort of program/master or bank/alarm clock. There would have been a pointer at the dial so you could precisely set the on/off, sounding of the factory bell/whistle or guard punch on duty checking in at each point on their rounds. I see the the electric rewind motor under the movement. I’m not proficient on master/program clocks. Hopefully someone will be along shortly with a better idea. It is definitely an automatic rewound clock, weight driven.
    Cheers,
    James
