Any help Indentifying would be great
Discussion in 'American Pocket Watches' started by Mikeinlodi87, Oct 20, 2019.
  1. Mikeinlodi87
    Mikeinlodi87 New Member
    Mar 9, 2019
    Picked this up at an estate sale , the case reads BWC co ? Wondering if anyone knows if this is a gold case
    Thank you
    94B10208-F810-4D59-B610-978554FB290E.jpeg ECC4B8A0-9115-4757-87A9-5473D0D16EED.jpeg DBFDCEE9-8525-48A9-8A29-55E79840D575.jpeg 8DAD724D-B6A0-41BF-8F86-B837F4E6D8B1.jpeg 8CE20DF7-E31F-419D-855F-677892DA3723.jpeg 145DABC0-3AC1-489A-9755-6F4032502AA2.jpeg FBEDC7B5-FDA2-4D5B-824E-8ADFBD2A5998.jpeg 5DD808AF-393D-434C-B5CB-7EF2F409C046.jpeg 88074860-26D9-44FD-8F9B-D76BD5DDE6D7.jpeg
    viclip likes this.
  2. richiec
    richiec Registered User
    Feb 24, 2007
    6,429
    343
    automotive warranty inspector
    Brick, Ocean, NJ
    Probably only gold filled, Brooklyn Watch Case Co. 6 size Elgin circa 1897.
  3. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    4,655
    2,118
    New York State
    Hi Mike and welcome to the NAWCC Forum.
    I would also say it's Gold filled.
    Plus you can see some braising(see non gold metal under gold layer) on the case
    Rob
  4. Rick Hufnagel
    Rick Hufnagel Just Rick!
    NAWCC Member Donor Sponsor
    Oct 25, 2018
    1,163
    1,426
    Plumber
    Pittsburgh pa
  5. Kent
    Kent Registered User
    Gibbs Literary Award NAWCC Fellow NAWCC Silver Member
    Aug 26, 2000
    18,272
    1,463
    Mikeinlodi87, et. al.:
    This is indeed a nice little watch.
    Page 112 of the 1904 Trade Marks Of The Jewelry And Kindred Trades book clearly identifies this stag trade mark, as others have noted, as a Brooklyn Watch Case Co. Granger grade case (as does the Brooklyn case paper - enlarged from an ad).
    However, the Granger grade case is not gold-filled. It is a solid gold, double-stock (14K outer layer, 8K inner layer) case.
    What appears to be "brassing" are shadows in the pictures, dirt/grime and possibly acid stains from testing. Also, some discoloration may be due to the fact that the 8K gold on the inside is only 1/3 gold, The other 2/3s of the alloy is made up of non-precious metal (i.e., base metal).
    1904_Trade_Marks_Of_The_Jewelry_And_Kindred_Trades_Pg_112.jpg 1890_Feb_Brooklyn_Granger.jpg 1890_Nov_Brooklyn_Granger.jpg
  6. Rick Hufnagel
    Oct 25, 2018
    1,163
    1,426
    Plumber
    Pittsburgh pa
    Thanks Kent for the correction. I had misunderstood that from the first time I read it. I didnt realize it was 14/8.
  7. Mikeinlodi87
    Mar 9, 2019
    Thank you guys for all your input I appreciate it very much
  8. richiec
    Feb 24, 2007
    6,429
    343
    Brick, Ocean, NJ
    As Rick said, thanks for the correction on case material, Kent, couldn't find that mark.
