Antique Mystery Tool
Discussion in 'Horological Tools' started by Dave Coatsworth, Nov 30, 2019.
  1. Dave Coatsworth
    Dave Coatsworth Senior Administrator
    NAWCC Business Sponsor
    Feb 11, 2005
    6,887
    1,756
    Watch Parts Dealer
    Camarillo, CA
    Does anyone know what this is? The box is about 3.5 inches square.
  2. gmorse
    gmorse Registered User
    11,085
    1,489
    Retired from Xerox
    Hi Dave,
    I think this may be a wheel stretcher.
  3. bruce linde
    bruce linde Technical Admin
    6,335
    690
    oakland, ca.
    graham - i’ve been hoping someone would answer... but what the heck is a ‘wheel stretcher’?!? o_O
  4. sharukh
    sharukh Registered User
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    Graham is correct.
    Sharukh
  5. gmorse
    11,085
    1,489
    Retired from Xerox
    Hi Bruce,
    The tool is designed to be held in a vice. The wheel, which is usually a replacement for a damaged one, and found to be correct apart from having too small a diameter, is set up in the sprung centres in the frame at top left, with its teeth between the punch at bottom left and the circular anvil. The punch is then gently tapped as the wheel is slowly rotated, stretching the rim of the wheel. The amount of stretching possible is clearly quite limited, but this was a viable repair to avoid having a new wheel cut.
    After this treatment it would probably need to be topped in a topping tool, to correct any irregularity in the teeth.
    musicguy likes this.
  6. sharukh
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    It's just that. It's used to stretch a wheel, ie, increase it's diameter. Don't ask me why. Maybe you need a wheel just a tad bigger in diameter than what you have.
    The wheel to be "stretched" is held by the arbor between the two centers in the smaller U shaped frame. The tool itself is held in a vise by the small stepped end that is visible in the upper right corner. The two frames are set apart just enough such that the edge of the wheel is resting on the small anvil in the larger frame. Then the wheel is "stretched" by hammering the punch such that the wheel edge is squished. You hold the punch lightly between your thumb and index finger and use your middle finger to slowly rotate the wheel in between punching. This rotating the wheel while punching is somewhat like you would do when staking a staff to a balance wheel.
    You would of course have to top the teeth after this "stretching" to get the correct tooth profile.
    I hope I haven't confused anyone. I don't think I can make it any simpler.
    Seems Graham just beat me to the answer by a few minutes.
    Sharukh
  7. Dave Coatsworth
    Feb 11, 2005
    6,887
    1,756
    Watch Parts Dealer
    Camarillo, CA
    Thank you very much, guys!
  8. karlmansson
    karlmansson Registered User
    Apr 20, 2013
    2,592
    Doctor
    Linköping, Sweden
    Never used one, but from what I'm told it can also be used to stretch a wheel in a single spot at the rim to repair a damage tooth. You would then use a topping tool on order to bring it back to pitch diameter and shape the tooth back to it's original profile.
  9. Kevin W.
    Kevin W. Registered User
    22,241
    311
    I was thinking wheel stretcher too, but was having trouble to find something on it, when searching on the internet.
  10. Dushan Grujich
    Dushan Grujich Registered User
    Jun 20, 2003
    577
    37
    Watchmaker
    Bondi
    G'Day!
    Not much can be found on the net, old books do provide answers, e.g. in the writings of Claudius Saunier, one can read about the way the jobbers made wheels by hand.
    Essentially, wheel stretching tool was used to correct improper depthing caused by eccentricity of the wheel. In the old days wheels were in most cases made by hand filing, sometimes ending up with slight eccentricity. Thus to correct the eccentricity of the wheel, they were first corrected by stretching followed by rounding them in the rounding up tool, at the same time correcting the shape of the teeth.
    Cheers, Dushan
    Kevin W. likes this.
  11. praezis
    praezis Registered User
    Feb 11, 2008
    448
    21
    Germany
    #11 praezis, Dec 1, 2019
    Search older watchmaker books, not the internet and you will have success...
    Frank
  12. Dushan Grujich
    Jun 20, 2003
    577
    37
    Watchmaker
    Bondi
    G'Day Frank!
    Myself, I found welt of info in the periodicals of the like of "Deutsche Uhrmacher-Zeitung", for those that are interested, most of the issues can be found online.
    Cheers, Dushan
  13. bruce linde
    6,335
    690
    oakland, ca.
    thx for the info... learn something new every day.
    PatH likes this.
  14. sharukh
    Oct 10, 2011
    353
    14
    Doctor
    Mumbai, India
    Guten Tag Dushan,
    Aber, Ich spreche nicht sehr gut Deutsche. :)
    Unless you can point me at some translations.
    Sharukh.
