Antique long-case grandfather's clock age?
Discussion in 'Your Newest Clock Acquisition' started by PeterDixon5775, Dec 24, 2017.
  1. PeterDixon5775
    PeterDixon5775 Registered User
    Dec 23, 2017
    IMG_20171223_172551.jpg IMG_20171223_172447.jpg IMG_20171224_095454.jpg IMG_20171223_172551.jpg IMG_20171223_172541.jpg IMG_20171223_172535.jpg IMG_20171223_172527.jpg IMG_20171223_172500.jpg Posting pictures of the mechanism. There is no markings anywhere. Can anyone provide any information, date or maker from the pictures? IMG_20171223_172447.jpg
  2. P.Hageman
    P.Hageman Registered User
    Jul 20, 2014
    976
    147
    Forensic science
    The Netherlands
    I am not an expert on American longcase clocks, but the movement is for sure a Black Forrest 30 hour. The way this movement is made, I think it dates from circa 1840-1850. I know these movements were used also in longcase clocks, although one would axpect an 8 day movement inside. I think the case is American made arround the same period. I have some questions as it comes to the painting of the dial, it looks as if it does not fit the mask of the hood? Or does it sit too low in the case when you took the picture?
  3. PeterDixon5775
    Dec 23, 2017
    The dial is just sitting inside the face of the case while i have the works running on the bench. The dial attaches to the movement and sits nicely in the case. Thank you for your comments
  4. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,661
    98
    Cabinetmaker,clock repair
    Moultonborough,NH
    Just to add..clocks of this nature were not uncommon in the Philadelphia and surrounding area of Pennsylvania because of the large German immigrant population.
    Hope this helps.
    tom
    BTW a nice example
  5. chronologiker
    chronologiker Registered User
    Jun 28, 2017
    360
    27
    #5 chronologiker, Dec 24, 2017
    I think the movement does not belong to this clock, because the hole in the dial is too large.And the movement is later.
    As Hageman said, I also would expect a 8-day wood-spindled BF movement in this clock.
    Chronologiker
  6. PeterDixon5775
    Dec 23, 2017
    This movement has an alarm that takes up the large hole in the dial the face fits very nicely in the case and the alarm seems to work
  7. Chris Radano
    Chris Radano Registered User
    Feb 18, 2004
    3,690
    212
    Pennsylvania
    #7 Chris Radano, Dec 25, 2017
    When you get a chance, please put the dial on the movement, then put everything inside the case. Then, take some more photos of the movement in the case, and the dial with the glass door closed. But if someone said the clock is from the 1840s-1850s, that is a good guess. Looks like the case is cherry wood with a dark finish.
  8. Jim DuBois
    Jim DuBois Registered User
    Gibbs Literary Award NAWCC Member Sponsor
    Jun 14, 2008
    3,008
    676
    Magnolia, TX
    We find many 30 hr clocks circa 1800-1850 in that general area, namely central and western Pennsylvania. Some fair number are 30 hr black forest, but 30 hr brass painted dial clocks are even more common, sometimes even brass dials, often with some really high styled finials and carved decorations, fancy flutes, heavy cornice moldings, and other fairly extreme and very well done case enhancements. Many of these clocks are "cosmetically deserving" of 8 day movements and some of the really nice cases get converted to 8 days clocks as the 30 hr versions are very hard to sell.....not a recommended thing to do, but it happens often. The later clocks often have turned feet.
  9. chronologiker
    Jun 28, 2017
    360
    27
    That´s a good idea. Please take some more photos, when everything is mounted.
    Aren´t the weights very heavy for this 1-day movement?
    Chronologiker
  10. PeterDixon5775
    Dec 23, 2017
    Yes the weights are heavy. I have everything back together and working here are pics, I have to center the dial a little more
  11. chronologiker
    Jun 28, 2017
    360
    27
    #11 chronologiker, Dec 28, 2017
    Thanks Peter for the pictures. We see, everything is ok with your clock.
    If you want to find out more about these Black Forest movements in cases from Pennsylvania, I recommend Doug ("Duck") Stevenson's article in B. Schaaf's book "Schwarzwalduhren" (4th Edition 2008). Although the article is in German, it will inform you very well about your clock. Highly recommended!
    You can try to get a copy through the NAWCC library.
    Chronologiker
  12. chronologiker
    Jun 28, 2017
    360
    27
    The name of Doug Stevenson´s article: "Schwarzwalduhren und Amerika"
    Chronologiker
