Antique lathe/cabinet?
Discussion in 'Horological Tools' started by wow, Sep 7, 2018.
  1. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Retired Music Minister
    Pineville, La. (central La.)
    #1 wow, Sep 7, 2018
    I posted info about acquiring a long-time clock repairman’s complete shop in the clock repair section of the MB. I will probably be asking many questions about the many tools I got later.
    This post is about a very old lathe/ cabinet that I got. After looking it over carefully, I think it is not all original. The cabinet is very heavy, primarily due to the large drive wheel and it is made of heavy solid wood. The wheel has a small belt grove in it that appears to have driven a small lathe or something similar. I do not know about the lathe on top. I see no name anywhere. The gentleman I acquired it from has dementia to the degree that he does not remember anything about it.
    What do you think?
    (link added by shutterbug)
    6197C299-5013-46F3-8BF6-7E8D91DE1F57.jpeg DA65512C-4735-4709-84E8-194B1E240BE6.jpeg 3E2BA343-42AC-4625-A435-9CB6D45A7556.jpeg 13B7A1D4-76BF-43F8-890B-1A59951AA4B6.jpeg
  2. shutterbug
    shutterbug Super Moderator
    38,197
    310
    Maybe a foot peddle to operate the lathe?
  3. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Yes, I think so. The two slots on top next to the lathe at there for the belt. I do not think the lathe is original, though. The pedal wheel works well and evidently was used during pre-electricity times.
  4. kevin h
    kevin h Registered User
    Apr 9, 2015
    361
    94
    cambridge md
    Since the lathe does not line up with the belt grooves , I suspect it is a replacement, there where so many early lathes only a few made it through the time test of usefulness, or the pedal drive operated a buffer ( for a jeweller) or grinder , it would have been hard to use a pedal operated lathe in my opinion ,it is still a nice piece of history .
  5. gmorse
    gmorse Registered User
    9,397
    590
    Retired from Xerox
    Hi Will,
    The pedal flywheel could possibly have worked a lathe, but I can't see how you could use a lathe properly mounted in its current position, unless you sat on the other side of the bench, because it's just too far away from the front. The single slot with the mark of a lathe foot nearer the front seems more practical, but I think that would have to have had a motor.
  6. trim
    trim Registered User
    Feb 19, 2010
    151
    7
    For sure, I have seen exactly this treadle setup currently in use, as you might notice from another thread in here - so that was its original function and apparently works well. Overall, the bench and foot wheel look very much like those I have seen old catalogues, so I would say you have a very nice setup.
    The milling vice mounted on the corner is fairly modern.
  7. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    #7 wow, Sep 7, 2018
    Trim, I would love to see that thread. Have any idea where to look?
  8. trim
    Feb 19, 2010
    151
    7
    I just mentioned that I saw this foot setup still in use by a Amish watchmaker named Joe, in WI recently, with the whole workshop being foot powered - including a modern milling machine, with exactly the same foot unit you have. One thought, while the holes don't line up with the current lathe, perhaps an intermediate/transmission pulley was also installed at some point. This is the only photo I took of the setup of the foot wheel in Joe's workshop.
    I'll see if I can find a catalogue photo of a similar bench - can't recall where I saw it atm.
  9. Troy Livingston
    Troy Livingston Registered User
    Aug 28, 2006
    143
    Aerospace Stress Engineer
    Melrose, FL
    Nice bench. It is rare to find them with the treadle still inside. Your lathe is in the wrong spot, the ring mark towards front of the bench is where it should be. You are missing the lathe jack, an intermediate set of pulleys, these are frequently seen on the online auction site. The nut on the lathe base can be loosened so you can pivot the lathe out of the way when it is not in use.
    A photo of a recently acquired bench.
    The first time I turned on a treadle lathe was an eye opening experience. I was a bit frustrated with the typical sewing machine motor arrangement on most watchmakers lathes. A friend suggested I try his treadle lathe, all the torque you could ever need at any speed, much nicer than the typical sewing machine motor screaming in your ear. It can be work though. Turning with a T-rest and graver is quite pleasant. Using a cross slide requires you to stand so you can see past the tool post.
    It took me years to find my first lathe treadle and during that time I discovered the Sherline lathe motor.
    A bit more practical, all the benefits of the treadle plus it runs on electricity.
    Set your lathe up properly and try the treadle. If you don't like it you can always drive the lathe with a motor.
  10. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Troy, thanks for such great info. When I got it, the lathe was installed properly. I couldn’t figure out how the belt could drive it in that position so I moved the lathe to the back where the slots were. Now I understand. I am now in the market for a lathe jack.
  11. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Two of the other lathes I got were Sherlines. One is a 4000 and the other is a 4345. Now I have to learn how to operate them. I do have an old Unimat SL that I have used for years, so I am not a total greenie to this type. They are similar but quite different. Guess I’ll start reading on the Sherline and get basics. Any help on the 4345 would be appreciated.
  12. Troy Livingston
    Aug 28, 2006
    143
    Melrose, FL
    Since there have been no replies.
    You might try looking at Tabletop Machining by Joe Martin. (Available from Sherline)
    Also if Jerry Kieffer still teaches his lathe class at the NAWCC school you might consider signing up.
    Years ago I took his wheel and pinion cutting class and found it very worthwhile.
    Otherwise I have limited experience with the Sherline lathe and have been unable to find anything about the 4345.
  13. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Thanks, Troy. I am still unloading tools and parts. I was wrong about that model number. Both Sherlines are model 4000. One has a 4245 model number on the motor. Here are some photos of a few of the tools I’ve unloaded. Accesssries are still to be unpacked.
    6973229C-F9AA-4BF2-8171-705DC4CD9EB8.jpeg 842A554D-5FAE-48F3-A757-F522E82CABFC.jpeg 0FD9D635-D218-4782-B82C-5B650C81181D.jpeg A9BE17FE-D63F-4A06-8023-F1E42D3A4BAB.jpeg 7ED5CF43-F7E8-4320-91D7-0FF91EB9E200.jpeg 4A1D6EAA-B7B3-49B1-8DDC-6D0B01464CCC.jpeg
  14. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    I am still unloading boxes and found two sets of jewelers lathe collets today. WOW!
    Question: there is a set of several chucks for the Sherline lathes and milling machine. I have not found a draw bolt or bar for those. Should there be one? The chucks are threaded with about 1/4 inch threads.
  15. Uhralt
    Uhralt Registered User
    2,433
    167
    Yes, there should be drawbars. I think you can find what you need on the Sherline website.
  16. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Thanks, Rudi. I did go to the website and found it is a 1/4 x 20 x 5 1/4. I ran to Lowe’s and got three. Work great.
  17. Uhralt
    2,433
    167
    Glad I could help.
  18. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Ok, This dummy needs help. One of the Sherline lathes I acquired has an extra drive on the left end of the lathe. It has a separate power plug and switch. When I turn on the switch, the shaft that connects to the lower side if the head stock turns slowly. Nothing else moves. What is it for?
  19. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    249
    53
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    That's a power feed for the cross slide. There is or was a lever on the front under the headstock that works like a half nut to engage and disengage it.
  20. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Yes, Chris, I wondered what that lever was for. So rather than cranking the wheel, it slides it electrically, right? So is there a forward/ reverse? All I see is an on/off switch in the power line.
  21. Chris Radek
    Apr 13, 2014
    249
    53
    Lincoln, NE, USA
    I'm only familiar with the general layout of sherline's machines, not the particular (even older than mine) models you have, but I would not be too surprised if it only goes forward (towards the chuck) because that's when power feed is important to get a smooth consistent cut.
    Does your other one have a brass bed like it appears to?
  22. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    It does have a brass bed.
  23. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    I did get the power feed to work. The gentleman I got it from had not used it or any of the lathes for a few years. It was froze up. Dry. Lubricated it and it works well. Here are photos of the three Sherlines. Looks like they are all gonna work fine. Now I have to learn details of operation. Thanks for your input.
    Will
    4234A01B-88ED-42A2-B3A1-0FC7C84D72BB.jpeg A13D6D15-BDAE-471A-8D57-EC6D795D690C.jpeg 1759C60B-7F19-42F9-A0F3-F99816D8A2A0.jpeg
    Dave T likes this.
  24. NTimken
    NTimken Registered User
    Apr 18, 2012
    131
    Attorney
    Queens, New York
    I see a bushing tool in the cabinet. Could be a Bergeon, but it reminds me of the K&D one I have.
  25. wow
    wow Registered User
    Jun 24, 2008
    3,017
    80
    Yes, you are right. It is a K&D. In very good shape with all accessories. KMW.
