Hi Debra and welcome to this board.I would date the watch to the 1940's or 50's. Pery was a "private label", a business that had these made and cased and then sold them in the US.
The JXL mark is that of the importer which I cannot ID until I find a listing and it still may not be listed.
There is a mark under the balance wheel which is obscured but it is the maker of the movement. It is marked "Unadjusted" to reduce the import tariff. It is a basic ladies wrist watch movement cased in a novelty case.
It is probably near 14K gold but the mark has almost no legal significance. in the US, gold marked at 14 was rarely better than 13.5. The case is US made. Foreign gold usually has hallmarks
If you are going to wear it a lot it should get a service which should not be too hard since it is fairly modern watch. It would probably benefit from a crystal replacement. The dial has a yellow cast to it. If ths the dial color and crystal is clear, no problem but if the crystal has yellowed, it has to be replaced. When this happens, the gas from tehe crystal rusts parts of the watch.
It is good quality watch and I hope you continue to enjoy it.
