Ansonia
Nawcc123#
Dec 17, 2018
51
73
I have lengthened the spring and hook to the bottom of the adjustment and the adjustment on the bob is also at its end. It now has no furtur cearance for adjustments. The good news is that it is keeping good time. Would a heavier bob allow for adjustments in the future. I was also told that I might have some ability to adjust the verge to some effect.
Grant Perry
Jun 5, 2002
1,653
136
52
Ottawa-Canada's Capital
Hello,
It "sounds" like you are saying that you have lengthened the suspension rod and bob to the lowest lever in order to have the clock slowed and now it is keeping time? Please clarify. If so, there are other thinks you can do to provide for more flexibility in adjusting the speed of the clock such as a thicker (and/or) shortened suspension spring . From the picture it is difficult to see much detail. Can you post a picture with better lightening? Has the clock been recently serviced? I would advise not doing anything with the verge at this point.
Reactions: Nawcc123#
Nawcc123#
Dec 17, 2018
51
73
Hello,
I have lengthened the suspensin spring. Thicker sounds like an option. Ididnt know that there was such a thing.
15,633
2,137
Note, you have a twist at the very top of the suspension spring and the rating nut appears to be upside down.
I would suggest that you raise the suspension spring until that twist is just above the chops. This will get that twist out of play and also center your adjuster.
The pendulum will now need to be lowered but only about half the distance the hanger (at the top) was raised. This will raise the pendulum height about 1/16", maybe a bit more.
I'm curious about the "adjustments in the future"? If it's keeping good time there is no need to keep regulating. But, I would still recommend the just mentioned adjustments.
LaBounty
NAWCC Life Member
Aug 29, 2002
3,456
64
Mitchell, NE
www.abouttime-clockmaking.com
Opening up the bottom chops, where the suspension spring slides through, will allow the pendulum to swing farther and result in a slower rate. Opening the chops can be done by inserting a razor blade into the slot and giving it a slight twist or wiggle. However, opening the chops too far will result in pendulum wobble.
48,175
2,397
And if you were talking about a thicker suspension spring, that would speed the clock up. Thinner would slow it down because it allows the pendulum to swing further.
Nawcc123#
Dec 17, 2018
51
73
Thanks. New at this. Every bit f information is a help.
Nawcc123#
Dec 17, 2018
51
73
I will try this. Thanks.
Nawcc123#
Dec 17, 2018
51
73
This helped. Thanks
The addjustments are still as low as they can go but it is keeping correct time now.
171,029
1,493,237
50,083
3号缐
2,967
