ansonia
Discussion in 'Clock Repair' started by zzippy, Feb 26, 2017.
  1. zzippy
    zzippy Registered User
    Mar 23, 2016
    25
    can anyone tell me what the 4 1/2 ,or 5 or 5 1/2 relates to on the back bottom right of a Ansonia movement
  2. stewey
    stewey Registered User
    Dec 20, 2012
    974
    Oshawa, Ontario.
    I believe that the figures refer to the length of the pendulum in inches.
  3. shutterbug
    34,335
    29
    It's always a guess how they calculated those numbers. Some are from the suspension point to the middle bob. Others to the bottom of the bob. Some measured the length of the pendulum only.
  4. zzippy
    Mar 23, 2016
    25
    that's what I though got a lot of Ansonia clocks and all the pendulum's mixed up :( oh well where's the tape measure
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Those numbers are different enough that you could just put them
    on the movements and run them for an hour.
    It would be clear which were right and which were wrong.
    Any particular manufacture usually measures the same for all of their
    clocks. I'd say you can just line them up shortest to longest
    and try them out.
  6. Jim Hartog
    Jim Hartog Registered User
    Jan 6, 2010
    371
    house husband
    Hello,
    With Ansonia, I would try something which some have called "drop" and that is defined to be the distance from the hand arbor to the rating nut of the pendulum.
    Jim
  7. Walesey
    Walesey Registered User
    May 24, 2012
    573
    High School Science Laboratory Assistant
    Southern Highlands of NSW, Australia
    By way of confirmation, I just measured my Ansonia Parlour clock, stamped 8 3/4. It is in fact 8 3/4 inches from hand arbour to bottom of the rating nut.
    I finally understand the numbering system!
    Cheers
    Walesey
  8. TimeAgainRoy
    TimeAgainRoy Registered User
    Aug 23, 2011
    Thanks Walesey - I have written your pendulum information in my notebook - really useful.
Similar Threads - ansonia Forum Date
Ansonia movement with open barrels Clock Repair Friday at 9:55 PM
Ansonia Gloria and Huntress Parts Clock Repair Sep 30, 2017
Color of calendar hand on Ansonia wall regulator Clock Repair Sep 14, 2017
First successful overhaul - 1880's Ansonia Schoolhouse Clock Repair Sep 4, 2017
Ansonia project underway Clock Repair Aug 19, 2017
