Ansonia Venice Dial Screws
Discussion in 'Case Construction, Repair & Restoration' started by ScotSun, Sep 3, 2018.
  1. ScotSun
    ScotSun Registered User
    Nov 28, 2017
    58
    Computers
    Newark, DE
    I found an Ansonia Venice that just needed cleaning and a little brass polish on the dial face. The only thing that appears to be missing is one of the three brass fillister head screws that hold the brass dial face to the iron case.
    They appear to be size 4 or 5. I tried one of my size 4 and it goes part way in and does not turn so I am wondering if the threading is wrong.
    Does anyone know precisely what screw should be used and where to get them? For that matter, I am having troubles finding brass screws in general in the smaller sizes. Does anyone have a source for those? I did get a few from TimeSavers but the selection did not seem great.
  2. Troy Livingston
    Troy Livingston Registered User
    Aug 28, 2006
    162
    20
    Aerospace Stress Engineer
    Melrose, FL
    At least it sounds like you have the correct diameter and now only need to sort out the pitch (threads per inch). For a size 4 the more common pitches would be 36, 40, and 48. If you post a close up high resolution image of your screw on a piece of 1/4 in grid graph paper or next to a ruler I may be able to tell you what you need. If your thread size is still available then you should be able to order a replacement but it will likely bear little resemblance to the original. Are you active in the Chapters in South Florida?
  3. gleber
    gleber Registered User
    Jun 15, 2015
    1,735
    193
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    The best source I have found for original hardware is to check out old local hardware stores, not the big brand chain stores. If you ask, they may have some old stock. A local place has a good stash down in their basement. It was a pleasant find, but hit or miss and likely to be drying up.
    Good luck in your search.
    Tom
  4. ScotSun
    Nov 28, 2017
    58
    Computers
    Newark, DE
    I found a couple that I had that were not brass and someone else gave me the name of an internet resource. Thanks!
    I am not a member. But I plan to move up north, probably north Delaware area so will look into that then.
  5. breeze
    breeze Registered User
    May 2, 2010
    86
    7
    [QUOTE="ScotSun,
    I am not a member. But I plan to move up north, probably north Delaware area so will look into that then.[/QUOTE]
    Well you can forget the alligators but you will need a heavier coat.
    Breeze
